My Lathe project; might CNC it one day - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 87
Thread: My Lathe project; might CNC it one day
  1. #41
    Feb 2004
    hh
    Default Time for the next update
    Here is the newly installed Tailstock block; it's not qite all done; but is now useable for drilling; and if I can find the right bearing setup maybe pressed into service as a rotating center
    Differant angle to show the locking device for the stock; that is a 10mm bolt through the outer section of 6061 T651 and tapped into the inner section and clamps to the rail by compression
    Front view; the Rohm drill chuck (0-0.25") is mounted for now on a 0.500" dia mount; but as a #1 morse spindle will be fitted into the upper block the mount is temp; the spindle is ready to go into the Alum but the #1 morse has not arrived yet; nore has a #1 morse rotating center; the spindle will be threaded for in and out movement and another nice Knurled brass handwheel is to be made
    In this shot you can see the gouge I've made to increase travel of the X axis; I gained almost 12mm
    Similar gouge on the handwheel end; gain of 8mm
    X axis almost to the limit; total travel is now up to 91.5mm; I could gain a bit more at the expense of strenght; but I feel it's not worth it
    Top view of same
    My new Z axis spindle; this is a 6" extended air powered diegrinder front shaft; I'll be modding this into a Z spindle for the Lathe; the tailstock is way bigger than it needs to be; this is for a gridge to be bolted across the headstock and tailstock; on this bridge will be mounted the compound slide once the new toolpost mount is made; the compound will carry the new spindle with it's drive motor 30,000rpm and will be driven up and down by another Compumotor stepper drive and step motor; the software I use to control this machine will have 2 copies in the computer; one will be the lathe control; the other will be a 4 axis mill setup; a new timing belt drive will be added to the main spindle in the headstock; with a common timing wheel on the spindle and 2 options for drive systems; one system will be a DC ver drive with about the same top speed as now; the other drive will be a Nema 34 stepper motor and drive (300oz/"+ hold)
    With this system and by moving the Z axis off the bridge and mounting it to the cross slide (now Y axis as the mill) the spindle will become the 4th axis of the system (or a C axis) The Z axis of the lathe system will become the X axis of the mill
    With this setup I can have
    1/ lathe 2 axis
    2/ Lathe 2 axis plus steppable spindle
    3/ Mill with 3 axis (table is replacing the lathe toolpost; Z axis is on the bridge)
    4/ Mill 4 axis Lathe spindle becomes C axis; Z axis moves from bridge to Y axis mount and is useable over the C axis in 3 directions
    All in all a nice setup indeed once its all finished
  2. #42
    Feb 2004
    hh
    Default small mod to help the Z axis
    Well after a frustrating morning with dropped steps keeping me re-picking up my Zero's again (bloody crappy threaded rod; I have a ball screw coming)
    I figured untill the new ball screw and the Compumotor 2 stack 23 size stepper comes i'll use one of the Japan Servo KP86SM2-002 that I got
    Wow; some power heh I think that puppy would cut 1/2 hard 4140
    Looking from the tailstock
    looking from the headstock
    Nice thing is it will be 3 mins to return to the original setup with the handwheel again; I just removed the drive belt and handwheel; tapped 2 holes that you would never see and added the new setup
  3. #43
    Feb 2004
    hh
    Default small update
    I've removed the compund slide; it's not needed on a CNC anyway; if I need to taper I just program the taper
    I also lowered the tool post; I thought the chance to move to 3/8" sq tools was a good move
    The max before was only 1/4" sq
    The toolpost now has a nice P/Bronze bearing to rotate on too; before it was just a shoulder bolt; I still need to drill the indexing holes for the 90dgr points
    Another thing I did was to make the mount block so I can rotate it on the 2 1/4" dowels and place the toolpost more to the tailstock; never know it may come in handy
    The same mounting holes now drilled into the cross slide will mount the small mill table too; once the bridge is mounted the Z of the lathe will become the X of the mill setup Y will be the lathe X and the new bridge will carry the Z
  4. #44
    Apr 2003
    Ohio, USA
    Stevie,
    LOL, (bloody crappy threaded rod; ) , I take it then that you are not happy with that
    What do you have in mind for protecting the ball screw? maybe you could mill a rabbit all the way around and drop in a .125 or so fitted metal plate, possibly in two sections so it could be removed
    EDIT:
    Since you wont have the compound how does a CNC lathe deal with threading as I usually use the compound set at 29.5 and feed with that?
    Ken
  5. #45
    Feb 2004
    hh
    I got a 3/8" dia .4 pitch ball screw from eBay last week (not here yet) with 2 ball tracks and 10" of travel (litte short but good enough)
    Just need it to arrive and presto; fixed
    However the 34 sized stepper has cured the main problem
    It just sounds like an F16 on the run up ramp
  6. #46
    Feb 2004
    hh
    missed your edit
    I always just plunge my threads at work; I rarely add side cuts; if you thread fast enough you generally dont need to move sideways
    for a 1" dia thread I'd go 200rpm min usually faster if it's not blind
  7. #47
    Apr 2003
    Ohio, USA
    The compound feed was just how I was shown to thread, often wonderd why, speaking of which Why ?
    Ken
  8. #48
    Feb 2004
    hh
    me too; but over the years I've developed many better ways; and way faster
  9. #49
    Feb 2004
    hh
    Well now I'm really blown away with the capacity of this tiny lathe; I've been machining my tailstock spindle; this is from a multi head tapping machine once; it's got to be at least 45RC; I'm using a 3/8" sq carbide at 1500rpm; at 100mm/min feed; with .5mm cut; this little bugger takes it with hardly any chatter or slowdown; no stepper slips since the 34 went on; I'm using the micro center I made; still in the drill chuck
    The new spindle will shorten the distance the center is out; the #1 morse will be great for drilling and support; I was getting about 0.0025" taper over the 3.25" cut; but a simple addition to the gcode line made that go away in a hurry; not bad for a tough material like this; plus the slot for the drift is in there too creating an interupted cut at almost 5" out from the collets (the spindle is on a broken expanding reamer I've had kicking aroud for ever)
    I feel with the right suppot by the tailstock; this little gem can do a lot of work; the travel steady is the next small project for it (after the tail is finished) I also roughed out the small 4"x6" miling table to replace the tool post and mount today
  10. #50
    Feb 2004
    hh
    Default how to get perfect alinement
    Bored the Aluminum with a line bar using the 1/5" reamed hole as a guide
    The reamed with 11/16" to match the spindle that is on the tailstock
  11. #51
    Feb 2004
    hh
    Default In action
    Here is the lathe making it's own morse taper mount for the Rohm Drill Chuck; the plain jane 1/2" mount is turned down to a #1 morse; still need to make the knock out tang at the small end
    I also have to turn the threaded rod down to fit through the 5/16" hole in the spindle to push the morse taper out; the threaded rod (B7) will be turned at the back to fit 2 1/4x5/8x3/16 bearings and a handlwheel will be made just like the others from Bronze
    Next project for it is the traveling 3 point steady rest; this will be full adjustable and with have 5 x 13 x 4mm bearings to contact the stock being turned; the cross slide is drilled to mount the steady ( I think ahead sometimes)
  12. #52
    Feb 2004
    hh
    Default new leadscrew
    Here is the new antibacklash nut assembly for my Z axis
    The front nut (left side) is made from Ampco Bronze; the rear from Yellow brass; that spring is quite stronge and crushed about 1/8"
    The principle is the spring will keep the forces at opp sides of the flanks of the leadscrew; hence no backlash; the 2 staked rods keep the nuts in line with each other (the brass nut floats in and out)
    There are many way to do this; but as my space is very limited it what I had to do
  13. #53
    Feb 2004
    hh
    Default Time for another update
    The new 240oz/in stepper for the Z axis; complete with US Digital encoder
    As you can see the handwheel I stole for the tailstock
    Temp on this only moves 4dgr above room @ 2Amps/phase 2000steps
    The new 2 stack Compumotor stepper for the X axis; almost 80% more power; I was chking the temp rise with use and standby; hit 50dgr in the first config 1.5Amps/Phase; 40dgr(better) in the 2nd setting 1Amp/phase; still seems high but well within the specs (100C or 212F) again @2000 steps
    The finished tailstock; complete with stolen handwheel (hehehe)
    I need to remake another now for the Z axis
  14. #54
    Feb 2004
    hh
    The next update will be a big one
    A New headstck and spindle is planned with taper roller bearings with setable pre-load (2X Fag320006X and 55x38x8 oilseals)
    I got a 3" 3 jaw off eBay and I'll make a new more ridgid headstock to accomadate it
    I'm still collecting the parts for the 3axis mill conversion; so that update will be coming too
  15. #55
    Apr 2003
    Ohio, USA
    The incredible Mr. Stevie !
    I don't know how you do it but you are beginning to PI## me off
    Once again you have outdone yourself, while I remain a jack of all trades and the master of none.
    Nice, nice work Stevie.
    Ken
  16. #56
    Feb 2004
    hh
    Thanks Ken
    Well it has started to make it's self some money to pay for all the updates; as of now 36 barrels sold at $8.00US each; not bad; plus a few other things to make for cash too
    Nice when it can pay it's own way
  17. #57
    Feb 2004
    hh
    Default New Head update
    Finally got a bit of time in the shop to start the head conversion
    Here is the basic block bored for the Fag's and oil seals
    It's bored exactly the same the other end; once the spindle is installed with a lock nut to preload the taper rollers the head stock will just rock; I'll add a couple of threaded holes in the side and bottom for an oil bath supply; the oil will not be in the head all the time; but I'll circulate it to cool it; I figure with the high rpm's it will be making this will be a good idea
    Next will be finding time for the dual use spindle; I intend to make it accept ER25 collets without the 3 jaw; and the 3 jaw
    Also note the new drive belt for the spindle; this round belt made all the differance to belt noise and vibrations
  18. #58
    Apr 2003
    Hi Stevie,
    Nice work. I'm impressed.
    If you don't mind my backing things up a little, I have a couple of questions.
    How did you drill your linear rods to bolt to the bed?
    Second, How did you bore for and what kind of bearings did you use for your carriage?
    Your new headstock looks great also.
    Thanks,
    Chris
  19. #59
    Feb 2004
    hh
    Hi Chris
    Well the Thompson shafting is tough for sure; i used a carbide end mill at slow speed to punch the counterbore first; then drilled through with a 5mm carbide drill
    I Held the bed in 2 V blocks to drill through rail to the bed; once i got 2 screw in I removed the c clamps; they really did not sit well; but worked long enough for the first 2 screw holes
    The carriage bearing holes (I'm thinking you mean the crosslide shaft) were wire EDM'd at first with 8mm dia; but over the course of the project have changed a bit; I usually just stand it up in a good vice and dial it in with a 0.0001 finger dial (Mitatoyo) If however you mean the round guides; they were also Wire cut and the semi rough finish left by a 1 pass with the wire creates very small depressions for the oil to be trapped; these are no more than maybe 0.0001 deep
    When I made the tail stock; I no longer had access to the wire (moved jobs) I made the matching holes for the bed way with a reamer and the DRO for correct centers; this works almost as well; but the holes are very smooth and do not slide as freely (sounds weird) I then roughed them up a bit and that seemed to free it up (now there is somewere for the oil) very high polish on bearing surfaces can cause oil to not stick
    I was designing the new spindle last night (just 2D) and I can fit the ER25 Collets and the chuck in the same spindle; the front gets a bit complicated with the location diameter having to be used for both the chuck and the front section of a collet retainer
    The old collet spindle (which I was never very happy with) I will use as a V/H dividing head; I'll add a set of gears to it and a stepper
  20. #60
    Oct 2003
    Sweden
    "New Head update"
    What technique is used to make a hole like the one in the head block? Is it milled or turned, and with what tools?
    Looks really cool!
    Arvid
