My original reply:
NeoMoses wrote on 02-03-2004 02:33 AM:
Hi NAKD,
I'll help you as much as I can, but I would highly recommend that you post this in the forums to get others opinions on it, too.
Basically, I started with the manual Mill/Drill, bought servo motors from Dan Mauch (
www.seanet.com/~dmauch) Gecko 320s from
www.geckodrive.com, and a power supply off of ebay.
The brackets were all made from aluminum bought from
www.onlinemetals.com The timing pulleys, timing belts, and other accessories were purchased from
www.mcmaster.com
Finally, to remove backlash on the x and y axes, I used moglice from
www.moglice.com
Hope this helps. Again, I would recommend taking this to the forums, as many others are more intelligent than me, and can help you make this project happen for a little less money than I spent. Hope it helps!
