Bob,
Thanks so much for the info, again you always contribute so much. I torqued the collet down tighter than ever and still had the problems. Also tried using the same rpm and backing the feed down to 38 ipm, still chattered. Next I put the endmill in a weldon shank endmill holder and repeated the procedures and the results were worse than the collet. The best I can measure the chatter marks is about .o42" wide.
Delw,
Yes I have a partner 1 but I still think the machine is pretty rigid. I have seen the IH mills run .25" doc .5" wide cut at 100 ipm and I know that the milltronics machine is more rigid than the IH, given that it weighs about 4500lbs, but I maybe wrong in my thinking. Also my machine has linear rails so no gibs to adjust. I did check the backlash in all directions. In the X axis i commanded a .002" move, the machine moved .002, then programmed back to zero and the machine went to a little less than .0001 the y-axis was spot on, except when I commanded a .002" move it went .0021 but then it went back to 0.
I had a three flute carbide endmill that I use to run at 3600 rpm and 50ipm and it would cut like butter, just smooth.
I'm attaching a video and pics for you to look at
5500 rpm 77 ipm .5"width, .25" doc
5500rpm77ipm.mp4 video by dlenardu - Photobucket
Pic of chatter marks at 77ipm
http://i585.photobucket.com/albums/s...rpm77ipm-1.jpg
Video of 5500rpm 38 ipm
5500rpm38ipm.mp4 video by dlenardu - Photobucket
Pic of chatter marks at 38ipm
http://i585.photobucket.com/albums/s...rpm38ipm-1.jpg
Weldon shank marks at 38ipm
http://i585.photobucket.com/albums/s...shank38ipm.jpg
