Convert Sieg lathe to CNC
Results 1 to 4 of 4
Thread: Convert Sieg lathe to CNC
    Jan 2005
    Norway
    Default Convert Sieg lathe to CNC
    I want a lathe, I'm actually totally convinced that I need one.
    I could do with a Sieg C3, but I could also fit the C6b without trouble and both would be within my budget. I want to CNC it myself, and I've been looking for pictures and inspiration from others.
    Trouble is that I can't find many C6(b) conversions around. I find many started build logs, but few where one can see the final result.
    So if any of you have a build log or pictures of your finished conversion, I'd appreciate if you would share it with me.
    Registered selbuss's Avatar
    Nov 2008
    thailand
    Talking
    hi rozon
    i have just get my new c6b lathe and x3 mill from china
    do day i have desmantel the lathe and the mill for cleaning and start to convert it to cnc
    i will use the original acme screw in the beginning and change later to ball screw.
    no the lateh i use nema 23 motor387 oz and gecko G540 drive on my mill i use the same drive with 2 pc 387 z and one nema 906 oz bon he mill.
    i find information here and you can try this and here
    hope this help you and good luck with your build
    im working on a new cnc machine call MackMate and can be seen here thats why i buy the mill and the lathe so i can make part to the MM
    Registered Crevice Reamer's Avatar
    Mar 2008
    The C6 is limited by the 3/4 inch spindle bore. The Grizzly G0602, or one of its Weiss cousins would be a superior choice IMO.
    http://www.grizzly.com/products/10-x...al-Lathe/G0602
    http://crevicereamer.com/Page_85.html
    http://crevicereamer.com/Page_70.html
    CR.
    Too many PMs. Email me to my name plus At A O L dot com.
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    I agree with CR. Get the bigger machine if you have space.
    Regards,
    Mark
