Hi zoltan, I use silo 2 , use your displacment brush as a stamp, create a new brush then under image you just pick out the pict that you want to use as your new brush , make sure you have the grid subdivided a few times, and you have your brush strength up high, This method is ok for back ground stuff or a single stamp, but need work on tings with a lot of parts to it. try it out and maybe you can come up with somthing . still think yohudi's methode might be better. Graham
