decent rotary software for hand models
Results 1 to 17 of 17
Thread: decent rotary software for hand models
    Mar 2015
    Default decent rotary software for hand models
    Member awerby's Avatar
    Apr 2004
    Default Re: decent rotary software for hand models
    That all was done in "indexing" mode, and doesn't seem to have used more than 2 angular positions. So it really didn't require a 4th axis at all, just a way to flip the part over and carve the other side without losing registration. But the 4th axis, if you have it, is a good way to achieve that. I'd suggest DeskProto (which I sell at a discount) for CAM software that will do this with a minimum of difficulty and expense. It also offers "live" 4th axis routines where the piece turns as it's being machined, but you won't need that for these hands.
    Andrew Werby
    computersculpture.com
    Mar 2015
    Thank you, i have deskproto as a trial and i do like the software and much easier then most i am trying with but unfortunately i cannot for the life of me to get it to work lol. this is the result i get using the 4th axis option and looks all messed up.
    Attached Thumbnails Attached Thumbnails decent rotary software for hand models-hand-jpg
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Did you try sketchup? it`s free and very good at 4rth axis machining
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Sketchup does not create toolpaths, or do anything that a CAM program like DeskProto does.
    UCCNC 2017 Screenset
    Mar 2003
    Shelby Township
    Quote Originally Posted by reefy86 View Post
    Looks like you have a couple things going on.
    1) you need to rotate the hand model so that it's parallel to the axis of rotation.
    2) It looks like either your toolpath settings are incorrect, or the model may need to be scaled up or down.
  7. #7
    Mar 2015
    Quote Originally Posted by ger21 View Post
    i am following tutorials on how they do sculptures using 6mm ballnose for roughing and 2mm for finish, i have scaled it to the size of a human hand and rotated to parallel but still getting same result.
  8. #8
    Mar 2015
    not sure what i am doing wrong but if i scale the object up it adds more red cylinders like in picture 3 but if i scale down it has no detail.
    Attached Thumbnails Attached Thumbnails decent rotary software for hand models-untitled3-jpg   decent rotary software for hand models-untitled-jpg   decent rotary software for hand models-untitled2-jpg
  9. #9
    Jul 2016
    Philippines
    Yes Boss it can, you can do whatever you want in sketchup
    Out Topic: I finished working on my loading screen and main control page already boss and thanks to you
    Loading Screen
    Main Page
    Attached Thumbnails Attached Thumbnails decent rotary software for hand models-1-jpg   decent rotary software for hand models-2-jpg   decent rotary software for hand models-3-jpg   decent rotary software for hand models-222-jpg
    decent rotary software for hand models-111-jpg
  10. #10
    Mar 2015
    getting closer
    Attached Thumbnails Attached Thumbnails decent rotary software for hand models-untitled3-jpg   decent rotary software for hand models-untitled2-jpg
  11. #11
    Jul 2016
    Philippines
    @ OP If you can find a way to enclose your 3D hand model inside on a square tubular stock, I think it`ll be just a breeze, divide that tubular stock into 0.5mm and that`s it, sometimes autoCAM softwares made a hard time interpreting on a circular stock compared to a square stock.
  12. #12
    Mar 2015
    Quote Originally Posted by KH0UJ View Post
    Thanks, not quite sure how you do that in deskproto but i am learning
  13. #13
    Apr 2004
    I'd suggest using an indexed toolpath strategy in DeskProto instead of a continuous one. That way, you'll be able to reach the areas between the fingers which it's missing in the toolpaths you've shown. It would be easier for you to use the Wizard "2 or more sides, automatic rotation" at this point, which will set things up for you, rather than have to do all the settings by hand.
  14. #14
    Mar 2015
    Thank you, is there any way to play the simulation inside deskproto?
  15. #15
    Apr 2004
    It should be able to simulate the end result, but it won't animate the tool moving around.
  16. #16
    Mar 2015
    Thanks, i figured that out in the end but i still cant get in between the fingers cut out for some reason and also how do i get one side to rotate 45 degrees instead of 90? i followed through the wizard and i have 3 sides in total which are top, bottom and side but i want the side to be 45 degrees
  17. #17
    Apr 2004
    If you want to use the Wizard, then tell it the part has 8 sides; you can edit out whichever ones you don't want to use in the G-code (look for the A moves). Otherwise, set it up manually, with different Parts rotated to whatever angles you want, and chain all the operations together (in the Advanced tab).
