Please help.... "%" sign keeps showing up in code
Results 1 to 3 of 3
Thread: Please help.... "%" sign keeps showing up in code
    Dec 2010
    Default Please help.... "%" sign keeps showing up in code
    I have ran the same program now 10 consecutive times. Of the 10 times running 6 of those had "%" sign added randomly when machine is reading the code and not in one specific place which is really strange. I am stumped at this point on what it is. Any ideas ?
    Thanks in advance
    Apr 2009
    Default Re: Please help.... "%" sign keeps showing up in code
    Need more information before I can suggest what is happening.
    I assume you have a G-code file (Without % signs) and you are sending the file to a machine via a serial link (possibly dripfeeding). If so, there could be an error with the Communication setup itself either cable not correctly wired or incorrect serial communication protocol. "%" was often used to replace an unknown character in the data.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by 7379df View Post
    Thanks in advance
    It is normal to program a % sign at the start and end of your program, in some controls it will put it in if it is not there, I always use it even if the control does not need it, you set this up in your post processor
    What it does is signals start of data during file transfer.
    O3434
    N1G17G40G80
    T3M6
    M8
    G54
    S2250M3
    G90G0X0.Y0.
    G43Z.1H3
    G73G98X0.Y0.Z-1.1R.1Q.03F10.
    G80G0Z3.
    M9
    M5
    G53Y0.
    M30
    Mactec54
