Hey Guys, I have a question about which type of path in NX10 can I use to do some 3D milling with a T-Slot Cutter. I have a 3-axis machine and looking to "undercut" the body with a T-Slot Cutter. I can generate the tool to cut around the part but once it has reached the edge of the part it will not follow the body as it slopes back inward. It wants to cut straight down from that point. Just wondering if anyone knew something I don't to get this to cut underneath the outer edges. Thanks for any help.
** I forgot to mention the T-Slot Cutter has a full radius.
