Trying to figure out Rotary Axis
Results 1 to 8 of 8
Thread: Trying to figure out Rotary Axis
    Jul 2016
    Default Trying to figure out Rotary Axis
    Hello
    I am working with my cnc machine to come up with a rotary axis. I am currently stuck on working with the A axis to have it turn accuratly.
    My setup
    Cnc home build 3 Axis (2 steppers driving x)
    Aspire for toolpaths
    Mach3 mill
    Using the CNC Wrapper to convert X values to A values.
    Im Sure there is something i am doing wrong.
    Here is a Video and the G codes
    My setup
    Mach3 mill
    Attached Files Attached Files
    Registered KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: Trying to figure out Rotary Axis
    OK bro I can only teach you the perimeter method is it OK with you? I used a perimeter method all the time on the rotary axis, I dont have a clue either on the 360 degree side calibration, if it`s OK with you im gonna proceed with the illustration
    Jul 2016
    Yes please do !!
    Jul 2016
    Philippines
    OK then, you need to measure your chuck diameter, let`s use it as a reference on turning into 360 degrees, whatever it`s diameter size convert it to perimeter using this >>> Online Conversion - Circle Solver Calculator after that mark your chuck with a pen, center your dummy bit on the spindle to that on your marked pen on the outside of the chuck, let`s just say perimeter = 212mm, go to your mach 3 calibration page then calibrate it just like normal XYZ movement.
    circumference = perimeter
    calibrate it using the circumference value as a full 360 degree, so if you point your dummy bit on your marked position on the chuck it should stop at your marked pen when you enter the circumference value, copy your speeds ans feeds on your Y axis to your A axis on the ports and pins to have a reference, if it turns over your marked point, measure the over turn in mm to that dummy bit position.
    Jul 2016
    Philippines
    Trying to figure out Rotary Axis-capture019-jpg
    if the over turn let`s just say 26mm, add that number to the actual circumference, repeat calibration until the full 360 degree rotation of the A axis will stop @ your marked pen, you can do whatever you like on this method, ( custom TPI threads, gears, DOHC cam lobes, etc)
    sometimes it over spins while calibrating, in this situation just input a minimal number for example 10mm, always zero your bit on your marked pen then enter 10mm on the calibration page, whatever measurement it travelled input it again to the calibration, then zero again your chuck to the dummy bit then enter the circumference until it fully stops on your marker when you input the perimeter value then you`re done.
    Attached Thumbnails Attached Thumbnails Trying to figure out Rotary Axis-capture019-jpg
    Jul 2016
    Philippines
    Now on this method surface machining jobs are quite easy because you just draw it in a flat in a 3D environment and wrap the code with a G code wrapper, but on complex CAM designs like for example a whole car, you program the CAM first on a top then save the code, program CAM again on the bottom of the car then save the code, now it gets tricky open the top code in the notepad, add the command of the A axis (ex. 212 / 2 = 106) at the ending of the code then copy / paste the second code on it then save it as one file, once you input it on mach 3 the machine will do first on the top, once it`s finished it will rotate halfway then begin machining the bottom portion, it`s up to you if you divide the work piece by 2 or by 4, you just need to interconnect the codes while commanding the A axis on which to turn next then proceed with the next G-code set.
  7. #7
    Jul 2016
    A Huge thanks to you and your fast reply KH0UJ I was able to figure it out and do some rotary milling today....THANKS Happy Easter Have A great day
  8. #8
    Gold Member
    Apr 2009
    Find out the gear ratio for your rotary. Multiply that by the number of steps set on your stepper drive. Divide by 360. That gives you steps/degree.
    To do it as KHOUJ describes, take the diameter of your part surface, multiply by pi (3.14159265) to get the circumference. Divide the gear ratio by the circumference, then multiply that by the number of steps set on your drive. That'll gives you steps per surface unit on the part.
