Inch to metric conversion 1-1
Results 1 to 10 of 10
Thread: Inch to metric conversion 1-1
    May 2006
    Default Inch to metric conversion 1-1
    Hello and Good Morning,
    How does one get a cad model designed in inches to metric 1 to 1 values, 100 inches = 100mm
    I did a design in units(inch) thinking I can slam a conversion to keep the units and output metric units.
    I do not wish to use the 1/254*.1 to get screwy metric values in an inch system units.
    G21 at the machine?
    Thanks,
    Attached Thumbnails Attached Thumbnails Inch to metric conversion  1-1-detail-27-handle-underside-vu-jpg
    Been doing this too long
    Dec 2013
    Default Re: Inch to metric conversion 1-1
    Why not just rescale the drawing by a factor of 0.03984063745019920318725099601594, but tell the CAM program that it is working in inches. That should give you the output you want in inches.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Depends on the software, but in some cases, you don't have to do anything.
    UCCNC 2017 Screenset
    May 2006
    I designed in "units" thinking not to "set" mm and
    sure I can do the scale factor
    And get non-rounded numbers. which I used during drawing.
    Oops. shoulda started out differently..
    Does then, G21 tells the control that N000X000.000Y000.000Z00.000F000 is metric?
    Yes/No?
    Jim, Ultimately I'll get parts via 1/254
    I used to pass a parameter to the postprocessor
    Dec 2013
    Quote Originally Posted by bostosh View Post
    Yes/No?
    As far as I know, yes. Some air cutting might be in order to make sure of how things are going to react.
    May 2006
    Thank You, The client/customer freaked on this, when doing the volume calcs.
    A online quote system couldn't comprehend the units
    I needed a 100mm x 1mm piece of pyrex. not inches.
    I'll look for a decimal place converter /shifter
    Does the iges have it anyone.
  7. #7
    Member awerby's Avatar
    Apr 2004
    What CAD program are you using? Usually, they have a way to switch from one system to another - look in "options", "properties" or "parameters". But if you're starting with an even number of inches, it's going to give you "screwy" numbers in mm, and vice-versa. (To get from inches to mm, multiply by 25.4).
  8. #8
    May 2006
    Thanks for the responses, guys.
    I painted myself into a corner, I really thought this would be easier,
    And here is a confession. for Andrew
    I use Cadkey19 for reasons from very long ago in the 80's. ( I can hear laughing ?)
    This Cadkey is a derivative, functionally a PC version of what was developed internally at the aircraft factory, on Mainframe
    I found it !
    SolidWorks Import Solution: Wrong Units in IGES Files? - SOLIDWORKS Tech Tips, Videos & Tutorials from Javelin
  9. #9
    Dec 2013
    This Cad is a derivative, functionally a PC version of what was developed internally at the aircraft factory, on Mainframe
    In this century ins there a Cad system which can do this. in - mm conversion?
    I really was accustomed to picking up the phone and having the programmers add the function. mm/in
    Most CAD software today will do this. But in your case, you'll have to go over to the teletype and punch out a new tape.
  10. #10
    May 2006
    Once again,
    Science and technology overcomes fear and superstition
    Open up file in Notepad+ Change " 2,2HIN " to 2,2HMM" save
    I miss my punched cards, things were simple then.,
    Thanks Everyone !
