great work..
For Computer-Aided Manufacturing of trispokedovetiles, I've published a Javascript web-page -
Trispokedovetiles: CNC code to cut tiles web-page G-code generator [LINK]
- which generates Computer Numerical Control (CNC) code which I've tested with CNC Simulator Pro [LINK] but not on a real CNC cutter as yet.
My code was developed assuming a narrow kerf width as per laser cutting which should allow the tiles to be cut from a sheet "as assembled". Sorry but I've not yet developed any option to cut out close-fitting tiles using CNC cutting with rotary tools with their wider kerf widths. Maybe later when I can find the time.
In case you are wondering what a "trispokedovetile" is, it is the name I have given to a class of 3-spoke dovetailing tiles which fit together as per the attached image.
In case you are wondering what such shaped tiles might be used for, I have in mind interlocking armour tiles.
great work..
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
TRISPOKEDOVETILES ROUTER CUTTING
My trispokedovetile CAD-CAM webpage now offers an (X,Y,Z) option for router cutting using rotary tool paths between spaced out tiles.
I've simulated the CNC router code.
BEWARE BAD LINKS ABOVE!
I lost my website hosting in January. I was not "hacked" but the gcehosting administrator seems to have gone out of business and the hosting company he was using (godaddy) is serving various spurious adverts whenever anyone clicks one of my old links.
I have got the following pages back on-line with a different hosting company now so try these links.
LINKS
- Trispokedovetiles: Three-spoke dovetailing tiles by Peter Dow
- Trispokedovetiles: CNC code to cut tiles by Peter Dow
- Trispokedovetiles Gallery
I can't edit my earlier posts to correct the old links, sorry.
I've not done anything with this project since January.
