GrblGru: Free CAM and 3D-Simulation for mills and lathes - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 61 to 65 of 65
Thread: GrblGru: Free CAM and 3D-Simulation for mills and lathes
  1. #61
    Dec 2017
    Slovakia
    Default Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    Hello.
    Please take a look at why the gcode generated in inkscape is incorrectly loaded? In lasegrbl is loaded correctly.
    Inside zip file is extension for gcode creation into inkscape, dxf file, video as i tested it and gcode itself.
    Well thank you.
    Attached Files Attached Files
  2. #62
    May 2016
    Thanks a lot for your feedback. I am very interested in implementing a laser mode into the program.
    I will contact you after the holidays.
  3. #63
    May 2016
    Release notes V3.24
    the new version, availlable at https://goo.gl/quFpdZ, provides a new 3D model of a very nice lathe.
    It's a near 60 years old UNIMAT lathe, updated to a CNC machine by a friend from Austria.
    In the attached video I've documented how to create the toolpath and the G-code from an DXF or SVG drawing.
    Have fun with GrblGru
  4. #64
    Mar 2004
    Wisconsin
    I have to say, the amount of programming and the type and functionality of programming you are doing in this program is nothing short of amazing. I do not know of any control program that has visual affects to the point you have taken them.
    You may have read some other comments of mine regards your program and I do hope you take them strictly as constructive. In those comments, I have made it clear that the interface tends to intimidate anyone taking a first look, and that intimidation seems to make it difficult to negotiate, find or understand exactly what the steps are to use the program. Perhaps it is the blatant primary colors that could be tamped down a touch.
    I at first use was not able to get it to a Nano test set up I have here connect no matter what I tried, though other programs would connect. Then one day, it just connected as if there was never an issue. But I did not get far in attempting to test with it.
    Your videos show how much you put into your work. I wish there was voice over explanations because while you can click here, there, there again, here, over there.. we see things moving, but the video does not necessarily have the detail to SEE what is happening, and we all like to have a verbal explanation. This is the case with this last video with the black background and red lines. I could not figure out what was going on there at all on my PC.
    I had a discussion with a local who also opened the program and he too passed the program up rather quickly. He stated that there seemed to be quite a few completely non-traditional methods being applied. Not there might be reasons for this, given that grbl itself seems a bit upside down, inside out and backwards out of the box... at least until you adjust all those $$ settings to make sense for something other than a 3d printer.
    So the challenge for users is to figure out how to alter their traditional concepts to fit here. Even the simple things like the non-traditional axis labeling, not being normal to the majority of CNC lathes throws me off easily (your X is usually Z, and your Y is usually X).
    By all means continue with what you are doing. Perhaps when you get all the features you want programmed, you can swing back and focus on an ergonomic GUI, where the placements of what matters comes more naturally. For example, I've played with the program, even clicked on some of those buttons along the right vertical edge of the screen. But as I sit here, I for the life of me do not understand the value of them being there, rather than perhaps tabbed in a area where they might matter more.
    Your not alone with a non-ergonomic GUI for grbl... there are plenty of them. Only one I know of comes close to resembling a hobby based CNC control that the majority are familiar with. That said, there is no shortage of images on the web of what they generally look like
    I think my goal would to be to create an operator window that first worked with the traditional steps of:
    1, I need to connect to the control ( I don't need all the port baloney up front... that is a setting for behind the scenes or in a selectable setup file)
    2, I need to home the machine with a clearly defined home machine section
    3, I need open a G-code from my Cam program and I need it displayed clearly
    (I don't need to see the grbl data transfer details except when one must troubleshoot something)
    4, I need to jog/locate and set program zero for one or all axis
    5, I need to see clearly defined DRO sections for both work and machine positions
    6, I need to run the machine with a very clear cycle start button next to a clearly labelled Feed Hold button.
    Then I would look to putting all these secondary tool path creation and settings features on appropriate background tabs.
    Other than that, hats off to some obviously very, very detailed programming work !
    Chris L
  5. #65
    May 2016
    First of all, many thanks for your constructive criticism.
    All people who develop programs needs on this kind of feedback.
    And yes, I agree with you. For someone who is used to the conventional kind of surfaces, it is certainly deterrent at first.
    I think especially the new graphic possibilities require new operating strategies.
    In addition, documentation, especially in English, is not one of my strengths.
    Of course, I would like to personally introduce my program to you. That would be much easier for both of us.
    But the only realistic possibility for me is a maximum of 15 minutes of video with subtitles.
    It's not easy to pack all the functionality and information in this short time.
    In addition, in the last 3 years, I have developed a lot of stuff and also rejected a part of it, because at the end I did not like it any more.
    Only now do I slowly feel that I have found the essential framework.
    But because of the many changes in the past, it was not possible to create a reasonable documentation.
    However, I would also like to express my concern that the scope of the program is already powerful.
    It includes many functions that used to require a separate program like:
    - 2D-CAM program
    - G-Code sender for GRBL as well TinyG
    - 3D-Simulation program
    - STL Creator & Viewer
    and ....
    If you also think that some people have a program, for example, just to dimension a spur gear, and that they also have to pay for it.
    GrblGru will also do this work. It's only one of many other hopefully helpful function. And it's free of costs !
    I do not know how you feel at a new program, with a bit more complexity such as a CAD or a CAM.I can not remember that I liked a new program right away. My first attempt was always frustrating. I always curse terribly, because nothing works as I imagine. But if I read in a bit, and then try a second try after a while, things usually look a lot better.
    I take your criticism very seriously and will try to clean up GrblGru. I already have an idea how to make it easier especially for first-time users to get started. Give me some time. I will contact you here.
    Thanks again and please stay critical
