Metal Template Required (hopefully an easy one)
Results 1 to 2 of 2
Thread: Metal Template Required (hopefully an easy one)
    Mar 2015
    Default Metal Template Required (hopefully an easy one)
    Hi
    I'm looking for a template to be made to allow me to alter a pair of brake discs to fit my race car. I need to drill the new holes very accurately and was looking to bolt a template to the existing stud holes and then drill through the template to pilot the new holes. I'm really not bothered what they it is machined out of as long as it is strong enough not to flex when bolted down.
    I have done a design in free cad and exported it as a DXF and dimensioned PDF.
    I have an event coming up and would appreciate anyone who can do this reasonably quickly.
    Thanks in advance
    Aiden
    PS I have just noticed one of the dimensions has come out wrong. The R6 holes have a pad of 108mm The R3 holes have a pcd of 95.3mm. Thanks
    Attached Thumbnails Attached Thumbnails Metal Template Required (hopefully an easy one)-disc-template-dimension-pdf
    Attached Files Attached Files
    Mar 2015
    Default Re: Metal Template Required (hopefully an easy one)
    Job now completed, thank you
