Small turning work needed, 6mm X 27mm
Results 1 to 2 of 2
Thread: Small turning work needed, 6mm X 27mm
    Oct 2016
    Norway
    Default Small turning work needed, 6mm X 27mm
    Hello,
    I have this RLC-remote for stereo in which the knob potentiometer axle have broken, now i want to replace the axle but this potentiometer is unknown.
    Here is my drawings/blueprint! ( ATTACHMENT )
    Note! On the 6 mm end, the grooves/cut is not important as this is glued in place.
    Attached Thumbnails Attached Thumbnails Small turning work needed, 6mm X 27mm-img_0130-jpg   Small turning work needed, 6mm X 27mm-img_0133-jpg
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: Small turning work needed, 6mm X 27mm
    Why replace the spindle ?
    - Drill a hole where the part is broken
    - Press ( with 'Locktite" ) in a new pin ( use a piece off the back of a HSS drill that suits the hole size you drilled )
    - Turn pin down to correct size & groove.... job finished...
