I am looking to have a small item turned and was wondering if someone could provide me with a quote.
I require an 8mm rod 32mm in length with a m8 (1.25 pitch) thread cut 17mm into one end and 4mm into the other leaving 11mm uncut (I can provide a cad dxf if required).
The unthreaded section will eventually hold a needle roller bearing so will need to be relatively hard. I have some 8mm 304 precision ground stainless steel rod that may be suitable subject to your advice.
Is this possible to provide your email contact to us at this email address sl.wong@prototree.com
We will like to discuss further with you on this parts. Thanks.
