Laser / Waterjet Cutting 0.7mm Stainless sheet
Results 1 to 3 of 3
Thread: Laser / Waterjet Cutting 0.7mm Stainless sheet
    Aug 2013
    Default Laser / Waterjet Cutting 0.7mm Stainless sheet
    Looking for quotes to cut 5 sets of the attached from 0.7mm Stainless Steel.
    Accuracy is not a massive issue as it is purely a slot together item.
    If the holes in the second level baseplate are driving the cost up by a big margin, let me know, they are not essential.
    Lemme know what you can do?
    Laser / Waterjet Cutting 0.7mm Stainless sheet-render-jpg
    Cheers
    Attached Thumbnails Attached Thumbnails Laser / Waterjet Cutting 0.7mm Stainless sheet-assembly-pdf
    Attached Files Attached Files
    May 2015
    UK
    Default Re: Laser / Waterjet Cutting 0.7mm Stainless sheet
    Did you get these made or quoted for?
    It's easy to cut by our waterjet. You can visit our website here VICHOR Waterjet
    www.vichor.com The Global Leader in Waterjet Cutting Solutions. Top One in China’s Waterjet Cutting Market.
