Do you have an IGES or DXF file of these?
Hi, I need 2 aluminium levers cut for a flight sim project.
They are roughly 120mm x 30mm x 15mm, shaped in a sort of crank. I've attached a PDF for your guidance. I have the design in CAD or Corel or whatever you need.
I would appreciate a quote if you can make these,
Joe.
www.WebMachinist.Net
The Ultimate Online Source for Machinist Related Stuff!
Yes I have a DXF but I'm still refining the design, I simply wanted a ball park figure for these items. I imagine sending them from the US would be a bit expensive?
Based on 3mm internal rads minimum about £80 to £100 each
Hi Joe,
Is the quotation still open? If yes, please let us know at this email address sl.wong@prototree.com, so that we can work out the quoation. Thanks.
BR
/SL Wong
Sales Manager
Proto Tree LLC
website: Proto Tree
email: sl.wong@prototree.com
