UK RFQ'S
Page 1 of 3 123 LastLast
Threads 1 to 20 of 55
Forum: UK RFQ'S
UK RFQ'S
  1. Engraved SS Knob
    Started by GemFaceting‎, 02-19-2018 08:21 AM
    02-19-2018, 08:21 AM Go to last post
  2. WANTED. m10x1mm to 1/8 NPT HIGH STEEL ADAPTER
    Started by ros2468‎, 01-16-2018 07:19 PM
    high, npt, request for quote, requesting, steel
    01-30-2018, 05:06 AM Go to last post
  3. small aluminium shaft
    Started by barneskite‎, 12-04-2017 12:11 AM
    12-08-2017, 12:42 AM Go to last post
  4. WTH small mill work, sidewinder key.
    Started by ros2468‎, 09-13-2017 03:59 PM
    cad, key, rfq, sidewinder, small request
    10-08-2017, 12:03 PM Go to last post
  5. Wring for a touch plate on a CNC machine
    Started by Joe Lavery‎, 08-28-2017 11:12 PM
    08-28-2017, 11:12 PM Go to last post
  6. Metal Template Required (hopefully an easy one)
    Started by aideym‎, 03-08-2017 01:04 PM
    03-11-2017, 03:34 PM Go to last post
  7. Red face 100x35x15 Aluminium CNC case parts - 50 to 100 units.
    Started by JOGARA‎, 02-11-2017 05:24 PM
    cnc, made, part, parts, units
    02-16-2017, 03:04 PM Go to last post
  8. Post 40x40x3mm aluminium plate milling
    Started by Doub‎, 02-03-2017 01:48 PM
    02-10-2017, 10:01 PM Go to last post
  9. Machining service wanted
    Started by JonathanW17‎, 12-14-2016 05:15 PM
    axis, europe, jonathan, machine, molds
    12-14-2016, 05:15 PM Go to last post
  10. Small turning work needed, 6mm X 27mm
    Started by mrmillermachine‎, 10-13-2016 08:32 AM
    10-14-2016, 06:48 AM Go to last post
  11. Need to hire CNC/mahcine time service
    Started by seanmore‎, 09-25-2016 11:29 AM
    carving, cnc, forum, tiles, time
    09-26-2016, 05:51 AM Go to last post
    09-01-2016, 02:53 PM Go to last post
  12. Cnc Ruoter quote
    Started by omnisales6‎, 07-15-2016 12:44 AM
    07-15-2016, 12:44 AM Go to last post
  13. Small Turning work required
    Started by adsey‎, 01-23-2016 05:02 AM
    02-23-2016, 07:08 PM Go to last post
  14. need some turning
    Started by petesurrey‎, 09-29-2015 05:23 PM
    expect, hardness, hrs, lathe, suitable
    10-06-2015, 08:02 PM Go to last post
  15. New product manufacture
    Started by paulcad‎, 08-30-2013 01:33 PM
    07-29-2015, 01:07 PM Go to last post
  16. Laser / Waterjet Cutting 0.7mm Stainless sheet
    Started by Hix‎, 01-20-2015 12:36 PM
    05-05-2015, 02:58 AM Go to last post
    04-12-2015, 03:53 PM Go to last post
  17. aluminium CNC , 4 off
    Started by tomekzal‎, 09-15-2014 07:15 PM
    10-13-2014, 06:14 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 1 users browsing this forum. (0 members & 1 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
