Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 01-29-2010, 08:48 AM
jlobin is on a distinguished road
Confusion on Old UHU encoder action
I have a servo motor that puts out 900 ppr. This motor goes through a 4:1 gear down to a 10 tpi screw to drive my Z axis. When used with Mach3, I find that I need to drive the motor at 144000 / inch for things to be scaled correctly. This is way too high. Can I use the "Step Multiplier (M)" setting in UHU to correct this?
Old 02-03-2010, 12:43 AM
H.O H.O is offline
H.O is on a distinguished road
Short answer - Yes, that is what it's there for. But you will be limited in the speed you can reach before the UHU starts loosing track of the encoder. The manual states at least 150kHz but I've found mine to gets confused abouve 130kHz. 130kHz in your case means 2166rpm/4/10=55IPM.
E-STOP Action kolias DIY-CNC Router Table Machines 112 09-03-2010 12:37 AM
Vid of my mill in action sdeering Mach Mill 3 03-30-2009 04:53 PM
Any used or see one in action- Multiplaz? DennisCNC CNCzone Club House 5 01-27-2009 02:10 PM
Need A Quote- Action Figure jfmenna Employment Opportunity 2 02-09-2008 08:13 PM
Saw it in action CNCadmin SolidCam 0 06-13-2007 06:00 PM
