Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 12-27-2009, 05:52 AM
gvb gvb is offline
gvb is on a distinguished road
new build
How do I wire the Estop and limit switches to my HY-TB4DV driver
Old 12-27-2009, 07:21 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
GVB,
The DB-9 connector is for the inputs
DB-9 Pin 1 = X-Axis Limit Parallel Port Pin 10
DB-9 Pin 2 = Y-Axis Limit Parallel Port Pin 11
DB-9 Pin 3 = Z-Axis Limit Parallel Port Pin 12
DB-9 Pin 4 = E-Stop Parallel Port Pin 13
DB-9 Pin 5 = N/C
DB-9 Pin 6 = Common
DB-9 Pin 7 = Common
DB-9 Pin 8 = Common
DB-9 Pin 9 = Common
Let me know if you need any more help.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 12-27-2009, 11:38 AM
gvb gvb is offline
Thanks any chance of a schematic diagram anyone
Old 12-27-2009, 06:35 PM
jalessi's Avatar
Post
GVB
Hope this helps,
Jeff...
Old 12-28-2009, 02:32 PM
gvb gvb is offline
Thanks guys it all becomes clear now
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
NEW BUILD: PVC as a build material Smiler DIY-CNC Router Table Machines 12 11-13-2009 04:57 PM
Newbie- I want to build my own. Crawler374 DIY-CNC Router Table Machines 3 06-02-2009 04:28 PM
New Large Table Build in Houston, TX (Build Log) anitel Plasma, EDM and other similar machine Project Log 12 12-30-2008 02:45 AM
