Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 05-18-2009, 05:51 AM
visky is on a distinguished road
Question h-bridge for high power motor
My plans:
-i want to use h-bridge from original uhu 160x100 board to drive high power motor ( 180Volt ,up to 16Amp ).
- step & direction will be PWM UP & PWM down signals outputed from Pluto-P board and closed loop made in EMC
Is this possible with original uhu board 70umm couper thick board or not ?
Regards
Old 05-18-2009, 10:50 AM
H.O H.O is offline
H.O is on a distinguished road
I don't think it is. IIRC correctly the problem (or one of them) is that the MOSFET drivers on the original UHU has a fixed deadtime (500nS?). This works fine with the specified MOSFETs and low(ish) voltage. But using "larger" MOSFETs and higher voltage the deadtime is too small so shoot-thru occurs, destroying the bridge.
The fact that the original UHU doesn't do well at higher voltages is the reason the HP-UHU was designed. If you wan't a bare-bones H-bridge/PWM amplifier I suggest you look at the one samco is working on. He seems to have nailed it pretty good.
High voltage & high power servo drive design Xerxes Granite Devices 32 08-22-2008 10:24 PM
High Torque , High Bandwidth Motor or Servo mastabib Benchtop Machines 0 09-26-2007 03:09 AM
How hard is it to figure out the size of cap and bridge rectifier for a power supply journeyonline General Electronics Discussion 10 04-04-2007 05:31 PM
H-Bridge high side floating supply niclatrique General Electronics Discussion 5 10-30-2006 10:19 PM
