Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 02-10-2009, 04:19 AM
contactirfu is on a distinguished road
Ben's UHU saga
I read old thread about uhu ,seams here you are still writting about. I received this days controller from Uli , and pieces on reichelt .de . I have soldered two controller board{from 6}.,and just i expected after i readed many experience before me..... i neeed helpp.
1. i cant test uhu board .. dont know..maybe encoder ..i put on pc those 2 green led are shining, error led is ok vhen i put error on uhu soft control, is ok pc see my board but i cant move my motor ..sometimes he goes away alone in one direction.
motor for testing is shinano kenshi dx050..encoder 200lines 90degrees 2 chanel 4 wire { i have other bigger but encoder on them are not ok for uhu-3 wire max 50 lines.."} please tell me is encoder is ok for uhu is TTL???i put some encoer specs atached here.
2.i tested voltage everithing is ok but i dont know german and as in picture in place of 0 volt is 5 on my board{dont know what say there about measuring where to put -of multimetter?)is a problem somebody cheked that diode and iss not ok 5 volts?{ i measured all pind with - on the uhu board an + on each pin all but there i got 5}
3. can you give me some layot schems and docs for encoder receiver emitter for differential lines?if my encoder is not ok i can update him with differental lines to work in uhu?
4.some simple step dir program for testing servo???or tell me step by step how to run from uhu soft{E 2000 G 30000??ANS HE WILL RUN?}
5.btw i want to build an wood router for sculpture..hope i succed and dont regret a lot of money sped without result
6 thx . i know i will find here help ..i watched you for about 2 years nice guis..
best regards: ben
forgot another thing to asc what about with those colored pins on ic's?
and please help to do breakboard for 3 axys..image detail ..{for me a beginer in electronic and this domain an image make more thamn 100 words and her e s my controller
ID:	75358   Click image for larger version
Name:	UHU Voltage Check2.JPG‎
Old 02-10-2009, 04:20 AM
HI Ben - since you were starting to clutter my thread I started a new one for us to clutter and fill up.
answers soon.
RGDS
Irfan
Old 02-10-2009, 04:34 AM
Originally Posted by contactirfu View Post
reverse the leads of the motor - it should work -
think Henrik can shed more light on your encoder -
I build the older schema - it did run low voltage - but never understood much of it - may be some one else can help.
oh yes it is here
http://www.cnczone.com/forums/showpo...9&postcount=18
when you download a copy of mach - you geta few demo programs which you can run - also you can use the arrow keys in Mach to jog.
ah I built my own
My steel frame small router (Madvac Inspiration)
best regards: ben
Thank you Ben - again a special thanks to Kreutz - Paul - Henrik and Jossi
here is one wonderful schematic for a BOB
http://www.members.shaw.ca/swstuff/bob.html
hope this helps -
Old 02-10-2009, 04:58 AM
H.O H.O is offline
H.O is on a distinguished road
The first, 200 line unit should work fine but the second one probaly won't. Only three wires sounds very strange for an incremental encoder and will not work with the UHU. Perhaps it's somekind of resolver or tachometer? Perhaps you can move the encoder from the small motor to the bigger one if you need to?
I can't help much with the hardware since I don't have the same version but check and recheck that all components (the diode and surounding components especially) is mounted correctly. If you could upload the schematic, board layout and instructions that you are building from here we could take a look at it. (Attach them to a post here please). I don't read German either but I can read a schematic - hopefully...
/Henrik.
Old 02-10-2009, 08:42 AM
chrugel is on a distinguished road
Do you get the controller up in the terminal window?
can you place the controller in analyze mode "A"?
if you turn the motor by hand with the encoder conected but not the motor wires, does a red led start to shine after about 2 to 4 turns? This action should cause a tracking error that exceeds the Error limit and thus sending the controller innto E-stop.
regards
Chris
Old 02-10-2009, 09:43 AM
benjon is on a distinguished road
yes i tested all the way of wiring..maybe too much...i still dont know if my encoder is ok for uhu...and yes i will change encoder on those bigger motors{btw how big must be motors on a cnc route for a nice speed ..?100..500 w constant power?}
this are schematic i used.and down on page is tension on board..http://www.gertronik.de/cncecke/servo.zip
Old 02-10-2009, 09:44 AM
about BOB..you use that ? i read is for stepper ..and parallel not serial..is ok?
Old 02-10-2009, 09:47 AM
..and irf..i told you a pictur eis more than words .,your router is very nice goo job but ..pictures with your testing sculpture are better..that is what i want to see that words became practice..keep strait ..
Old 02-10-2009, 09:50 AM
yes i started A but just a vertical line go over and over again one time i pushed my screw drive some where and "a" go crazy..need to restart uhu board other way was like in electrocardiology
Old 02-10-2009, 09:53 AM
i read everywhere is like fashion to apologise for bad english.... i dont want to make discordant note and ar emy first few post till i learn how to be more concentrate ..sorryy.
  #11   Ban this user!
Old 02-10-2009, 11:09 AM
The vertical line going over and over again is like it is supposed to be
A going crazy is NOT the way it is supposed to be IF you carefully move the motorshaft back and forth. should be more like a sinus depending on how you moove it. It is easy to see each increment of the encoder here if everything works as it should. At least i can see that in my configuration.
That you have to restart the uhu is probably not a bad sign.
Your encoder should work if it is a quadrature output 5v TTL encoder.
Motorsize depends on machine size, required cutting force, acceleration, desired top speed, efficency of drive system etc. in other words impossible for us to say without a lot moore information.
My biggest motor is rated 140W continous power, and this is way to much in my configuration. i think i now use about 60 - 80 w on each axis and still this goes potentially very fast!
I'm not sure i follow you here, you intend to drive the UHU via the serial line?
That is not possible.
I use BOB to ease the interfacing towards the computer.
When the motor, encoder and UHU controller is set up properly this can be considered a stepper configuration since the interfacing is the same, step and dir signals.
regards
Chris
  #12   Ban this user!
Old 02-10-2009, 11:45 AM
ok this are thinks to make later now i must find that my encoder is ok for uhu ..this is first step for me other way i must buy some encoders i have 4 wire on encoder i dont know which is a , b and 2 i think are +and - but which?
two of them have some bulbs in them into some kinf os plastic isolation..are they ttl arent...
Irfan's UHU saga contactirfu UHU Servo Controllers 192 07-27-2009 11:09 AM
MY SM1 cnc mill PC control retrofit saga. zook HURCO 20 06-08-2009 09:46 AM
Need Help!- Ongoing Saga of a CNC Gone Crazy IQChallenged Gecko Drives 106 07-15-2008 08:22 PM
Moving Tormach mill to a basement - saga MichaelHenry Tormach PCNC 14 02-20-2007 12:19 AM
First Router - The Saga Begins dighsx CNC Wood Router Project Log 19 04-27-2006 04:50 PM
