Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
  #49   Ban this user!
Old 02-25-2009, 11:56 AM
H.O H.O is offline
H.O is on a distinguished road
Hi Ben,
Again, simply skip the circuit around the MAX6303. If you want the chargepump function then build a circuit around a 4538 or any other retriggerable monostable. It's not a replacement chip for the 6303 but it will work the same way.
If you can get 74HCT245 it will probaly work, if not try 74HC245. If 74LS245 is all you can source then by all means try that!
The74HC244 is not 'the same' IC as the '245 but will work if you change the circuit to match.
You can use the BC547 instead of the 2N2222 - no problems there.
  #50   Ban this user!
Old 02-26-2009, 03:06 AM
benjon is on a distinguished road
who can tell me about those BOB's trere are two 4,5 axys DIY boards and more ..[all free of hard to find pieces}they are compatible with UHU? you recomand me ???
http://www.pminmo.com/http://pminmo.com/4axis/4axisBOBdata.pdf
ben
  #51   Ban this user!
Old 03-02-2009, 08:40 AM
contactirfu is on a distinguished road
the one we posted previously is buffered and better.
  #52   Ban this user!
Old 03-04-2009, 01:45 PM
I have pieces for bob, but only max i founded was smd one in england,works in place of normal max?[i refer to power function , i know is another soldering mode,is the same number max 6303}
ben
  #53   Ban this user!
Old 03-05-2009, 03:01 AM
BEN U don't need the 6303 immediately - go ahead and assemble the rest. I use my router with some precautions without the charge pump.
  #54   Ban this user!
Old 03-05-2009, 05:18 AM
look here
  #55   Ban this user!
Old 03-05-2009, 05:21 AM
good
  #56   Ban this user!
Old 04-01-2009, 04:29 PM
again need help,
i have 2 breakboards,6 uhu controller ,50% pieces for router,money for other 50%,but motors must find cheap some.
my controllers are with irfp260n..who can tell me range of motors can handle...i found some big 14volts- 16amps,14 volts-30amps something about 100+ volts and 3-6 amps, and another litle 30v ,48 volts,27 volts.What power ,combination volt-amps can handle UHU??[i want something like200volts--xxamps to xxamps-xx volts]I refer of course at continuous work.
And somebody can tell me how to allign my 2500x1500 guiding lines on router suport table?[linear micrometer?? some experienced tips?? ideas? how can i be sure they are very straight??
btw..for 2500x1500 router what power i need for each axes??
ben
  #57   Ban this user!
Old 04-03-2009, 08:15 AM
for the router build start your thread here
  #58   Ban this user!
Old 04-05-2009, 05:54 AM
I m not at building step,i just want to buy some motors.Who can help me with what i ask in last post about motors? UHU BOARD with 4x IRFP260N : biggest amps -voltage can handle???
all best , ben
  #59   Ban this user!
Old 04-05-2009, 01:56 PM
kreutz is on a distinguished road
all best , ben
At least the original UHU boards that I tested did not handle those Mosfets well. Perhaps the PCBs from Uli have higher noise immunity. I would like to see the results of your tests.
Best regards,
Kreutz.
Irfan's UHU saga contactirfu UHU Servo Controllers 192 07-27-2009 10:09 AM
MY SM1 cnc mill PC control retrofit saga. zook HURCO 20 06-08-2009 08:46 AM
Need Help!- Ongoing Saga of a CNC Gone Crazy IQChallenged Gecko Drives 106 07-15-2008 07:22 PM
Moving Tormach mill to a basement - saga MichaelHenry Tormach PCNC 14 02-19-2007 11:19 PM
First Router - The Saga Begins dighsx CNC Wood Router Project Log 19 04-27-2006 03:50 PM
