Results 1 to 2 of 2
Thread: The reset switch
    Mar 2008
    Norway
    The reset switch
    I have two questions regarding the resetswitch on the UHU controller:
    1. question: Since my controllers is mounted inside a box i want to have the resetswitch on the front panel, can i wire the reset from all the controllers in paralell to one switch? I am pretty sure this should work since they all have common ground but hopefully someone else has alredy done this and can confirm that it works.
    2. question: sometimes when i turn the power off the motors start to spin untill the caps are discharged, usually about two or three turns. Can i avoid this by also pulling the resetswitch low when the power is off? Or is it better to use the emergency stop? And another thing, is this normal behaviour??
    regards
    Chris
    H.O
    H.O is offline
    Jul 2007
    Sweden
    Hi Chris,
    You should be able to wire them in parallel as long as they use a common ground, which you said they do.... Be carefull with this though because this basically extendes the PCB-traces without any sort of buffers in between so it might pick up noice and mess with the CPU which is not good. For this reason (and because I wanted to reset mine with a 24V signal) I used a PC817 opto-coupler for each drive, I mounted this close to the drive and then run the "LED-wires" for the opto to my "reset-signal" - works like a charm.
    I've never seen any motor movement while powering down but I always turn off the motor powersupply first (it bleeds out in ~2s) and THEN the low voltage power supply. In any case, pulling the Reset-line low should prevent it, I think.
    /Henrik.
  1. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-16-2008, 07:56 PM
  2. G320 error reset switch
    By jrslick22 in forum Gecko Drives
    Last Post: 11-03-2007, 05:58 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum General Electronics Discussion
    Last Post: 12-15-2005, 08:58 AM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum General Electronics Discussion
    Last Post: 11-01-2004, 06:58 PM
