Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 08-16-2008, 12:59 AM
southernexplore is on a distinguished road
Questions on the original UHU controller
What is the highest voltage and amperage you can run on the original boards?
I know its ratings but I was wondering if anyone has tested the old one or has been running them at higher voltage and amperage outputs with no trouble. I have 3 of the 10A/60V boards that have run perfect for almost 2 years now but with only nema 23 size servos on them.
I would like to run a lathe spindle with one and was wondering if the Keling servos would work! (specs for one of them is below)
constant torque: 1.2 N.m ( 170 oz-in)
-peak torque: 6.0 N.m (850 oz-in)
-max. speed at voltage constant: 4200 rpm
-terminal voltage: 72 VDC
-continuous current: 8.8A
-peak current: 40 A
-torque constant (KT): 0.14 Nm/am
-voltage constant(KE): 15 V/100rpm
-resistance: 0.52 ohm
-inductance: 1.8 mh
-inertia: 3.39 kg/cm^2
They have a larger one but I am not sure it would work.
Constant Torque: 1.6 N-m ( 226 oz-in)
Peak Torque: 8.0 N-m ( 1125 oz-in)
Max Speed at Voltage Constant: 3200 RPM
Terminal Voltage: 90V
?3?.03
Constant Current: 7.8A
KL34-180-90
Keling Technology Inc
Peak Current: 40A
torque Constant (KT): 0.182 NM/am
Voltage Constant (KE) 18.95 V/rpm
Resistance: 0.925 ohm
Inductance: 2.5 mh
Inertia: 3.4 kg/cm^2
I would probably run it with a belt drive 2:1 ratio motor to spindle.
Any thoughts are much appreciated!
Tommy
Old 08-16-2008, 01:52 PM
contactirfu is on a distinguished road
A HP-UHU kit would be the best for you. email uhu.highpower(at)gmail(dot)com
it would get you rid of all difficulties, however I have seen people on the German forum use the original design for motors upto 2KW, but not sure how stable they were or if stable what modifications were done.
RGDS
IRfan
About Wire EDM original in China Robine Product Announcements & Manufacturer News 11 03-14-2007 11:48 PM
Help With original Setup. Parallel port? tehMadmachinist Machine Problems, Solutions , Wireless DNC, serial port 2 03-14-2007 08:18 PM
Anyone replaced the bearings in the original steppers? badgs750 Bridgeport and Hardinge Mills 9 01-20-2007 04:02 PM
About Wire EDM original in China Robine Moldmaking 0 12-18-2006 03:14 AM
Blew up my original 5C BennettPrescott Haas Mills 7 11-20-2005 10:07 PM
