Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: DRO linear encoder for uhu/hp uhu
    Registered rokag3's Avatar
    Mar 2007
    greece
    Hello.
    there is DRO which are equipped with 5 micrometer glass encoder
    those encoder are quadrature and most of them differential (a+a-b+b-)with index often
    it will be very easy to amplify and recopy the signal
    i have made a little prototype with a motor for raising up or down a thread mill equipped with an trapezoidale screw and an impressive gear box
    i fixed it on a piece of wood with tape
    i use a linear mylar encoder from a printer and i put the signal on my hp uhu working at 24V for this experience
    guess that the rigidity of this was (censured)
    i put my comparator
    precision 1/20 of milimeters !!!
    with the motor moving a pure mechanical nightmare !!!
    there was some hunting on the begining but i manage to parameter uhu very well . this piece of .... was positioning very well.
    So i believe that with a very good encoder it can be done.
    i try to use a rotary encoder with poolie but vibrations make it very difficult
    Aug 2006
    Quote Originally Posted by rokag3 View Post
    Hello.
    i put my comparator
    Hello;
    Is there any way to get more info on those glass scales?
    Thanks,
    Kreutz.
    Feb 2008
    earth
    Thumbs up
    Quote Originally Posted by kreutz View Post
    Hello;
    Thanks,
    Kreutz.
    Hi Kreutz !
    check this out: Maybe the end of expensive encoders for UHU servo driver board it shows a pic of an encoder and its wheel (i think it's mylar, just a kind of rigid plastic) look at the transparent wheel on the toothed gear it has 1200 CT (counts !) and 200LPI (line per inch) this encodes the main shaft of the printer.
    Well, on the same printer there's a linear encoder made of the same mateial using the same sensor that the one on the pic, this encodes the printhead movement in HP printers (inkjet ones), the linear encoder is aprox 30 cm long and seems to be 200 LPI (do the math !), i have an HP PSC1510 & it uses the same encoders, the sensor is an Agilent.
    Regards,
    cnc2.
    Mar 2007
    greece
    Very detailed technical info
    http://www.heidenhain.com/wcmsmimefi...3_20_15180.pdf
    Unfortunately very expensive scale
    I am looking for much cheaper (same precision)
    there is some kits very interisting
    I have made a roller screw for my lathe my backslash is 4/100 mm this backslash mean 3.6 degres on my screw not a big deal to stabilize and avoid hunting effect.
    it is a chinese lathe i am sure that i can compensate with linear encoder
    backslash is the main
    Oct 2005
    the Netherlands
    heidenhains will xost you a knee and a rib new.
    Unfortunatly i think you will need to consider what quality DRO you want to use for feedback since a DRO that displays 0.00001" 'does not necessarilly say it is always precise ad repettitive to 0.00001".Heidenhains ARE, most of the time when installed exactly correctly but the cheaper ones sure ain't.
    I do believe it's the best feedback a machine can have since an encoder on your motor will only tell how many turns the motor/screw made and calculate theoreticalposition from there while a DRO will "take up all backlash" and only count actually moved distance though i can only guess to much backlash will make it a pita to tune the motors and maybe impossible if it''s not very repeatable.
    me no expert by the way so please prove me wrong and i will be the first to steel your design.
    Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
    Registered bunalmis's Avatar
    Jul 2003
    Turkey
    I use linear encoder at my milling machine. My machine doing 0.1 mm error by 5um encoder. (While aluminum machining)
    http://cnczone.com/forums/showthread.php?t=56761
    Aug 2006
    Thanks for the info. I think I could get a couple of Heidenhein incremental scales about 1000 mm each (for free) for testing. Will let you know.
    Oct 2005
    the Netherlands
    i can almost guarantee that of you het the heidenhain's to feedback it will be a kickass system you got running.And there might be some sadness when the owner comes to collect.\
    good luck.
    Jan 2008
    From a conceptual standpoint, linear scales are the way to go when it comes to determining where an axis is in its travel, but I have to think that they will lead to resonance in the system. If there is a small amount of slop in the assembly, the motor will have to compensate for this in each direction change, but the tuning parameters may have trouble dealing with this dead zone. Even advanced higher derivative PID control loops like the one used in the UHU can have difficulty with this type of system.
    Speaking from a strictly academic point of view, when the power to the motor is reversed, the UHU will take Velocity and Error into account, but will not understand the large change in required force to move the motor. With a traditional encoder, the UHU will register an edge much quicker than anticipated and will adjust power output quickley to avoid an out of control motor. With a glass scale, the UHU will not respond untill the axis moves, but the motor will have to rotate farther than anticipated with a less than anticipated force.
    While this seems desirable, the problem is servos are an error feedback system and only respond when an error is registered from the encoder. When an axis is not receiving movement commands, the controller is still hunting to ensure that it stays between the two edges of the encoder. With linear scales, this means it must rotate the motor thru the entire slop of the system and move the actual mechanical components.
    As far as what option is more controllable and or accurate, I have no idea. Either system could be accurate, but I highly doubt that linear scales will compensate for any significant mechanical slop without adding controll problems. If you really want an ideal system, use rotary encoders to drive the UHU and use linear scales to interface with the control software and use feedback from both the linear scales and the error parameters on the UHU to compensate for any error. The linear scales can easily be fed into a PC, but I have no idea what software can do the number crunching and motion control fast enough to be of any use.
    Mar 2007
    greece
    hello,
    still looking for the cheap one.
    but i can say that in order to do it you must be used to trim servo i have seen that the response must be less nervous if you have mechanical backslash
    i can imagine that a lot of tester have been trapped by that because you like to have a very fast feeling this is a wrong approach , make it slower to respond so your servo will not hunt and then make it a bit more nervous but never forget that this is real motion and not an elasticity or a compression it's a full load real move !!! that's why it should be cool
    uhu is perfect for this job Mr. bunamis you should try it and i am sure that you will have something much better 1/10 th mm
    Oct 2005
    the Netherlands
    i've seen some old anilam controlled bridgeports that used lineair scales as feedback and they rocked *ss and these were setup in the 80's.They did use both tacho as lineair feedback though and i can barely imagine a backlash-free bridgeport.
    I can imagine a servo rocking back and forth to compensate for backlash whilst attempting to hold a position under load. If this feature can't be turned off and "assume" the cuttingloads don't exceed the drag of your ways(almost nil with rails)or some breaking sytem for when a specific axe is not moving. When going 0,0005 a breaksystem might be a usefull feature anyway.
    Oct 2006
    Hi all,
    I run a machine called a prototrak DPM. It's a bed mill that makes use of both linear scales and rotary encoders. The ball screw in the X axis currently has about .003" backlash. The machine compensates very well. The motor tuning is automatic. I just type a service code into the control and it jogs the axis and measures rotary feedback against the linear feedback and the machine configures itself. Not too shabby for a DOS based system.
    Motor hunting is an issue in this type of system. While taking heavy cuts across the Y axis I can see the X hand-wheel jogging back and forth to comp for the slack in the system.
    I use the machine for 3D surfacing of permanent mold cavities and it performs very well. Even with the backlash it will still interpolate a circle within .0005 out of round. It's all in the tuning.
    I just wanted to let you all know that it can be and has been done. How to apply it in a home built system I don't know. It would appear that you will need real time feedback monitoring by the control not just a closed loop driver with a "blind" control.
    hope this gets the wheels turning
  • Page 1 of 3 123 LastLast
    1. Linear Encoder Information
      By jlaiken2 in forum General Metal Working Machines
      Last Post: 07-28-2008, 09:23 PM
    2. linear encoder question
      By cnctiger in forum General Electronics Discussion
      Last Post: 04-27-2008, 09:34 PM
    3. Linear Mag. Brake + encoder stylus ?
      By jethro in forum DIY CNC Router Table Machines
      Last Post: 11-07-2007, 01:57 PM
    4. linear encoder wires ??
      By elpete0068 in forum General Electronics Discussion
      Last Post: 06-25-2007, 11:38 PM
    5. Linear Encoder Question
      By Verboten in forum Linear and Rotary Motion
      Last Post: 08-30-2003, 04:04 PM
