Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 06-30-2008, 05:35 AM
vroemm is on a distinguished road
The UHU parts list, questions and improvement.
Here you can find the partslist for the UHU http://gsst.wikispaces.com/UHUget
Questions or improvements can be discussed in this thread.
Old 07-05-2008, 05:46 PM
rtfm is on a distinguished road
Talking UHU Parts
Anyone still selling parts kits for the UHU Servo Board?
Old 08-10-2008, 06:50 AM
Andrey67 is on a distinguished road
Is it possible to use inductor PM2120-2R2M-RC insted of PM2120-1R2M-RC on UHU HP (L1,L2)?
Old 08-10-2008, 12:29 PM
kreutz is on a distinguished road
No, it is almost double (2.2uH) the inductance of the right one (1.2 uH), also the saturation current is lower (19 Amps)...
Old 08-10-2008, 04:55 PM
To clarify the value of the following components C14 and C18 (tantalum or electrolytic)?
What are jamper's (RST1 and P3) on PCB's for and if it's necessary to install (to short-circuit) them?
Old 08-10-2008, 06:10 PM
For HP_UHU only: C14 and C18 could be tantalum capacitors. RST1 is a reset jumper and should be normally open (briefly closed for hardware RESET). P3 is a test point for GND potential, it is permanently shorted on the PCB by a thick copper trace. P3 serves as a test point GND for the oscilloscope, and as a auto-router trick to separate Power and Logic GND while auto-routing the PCB.
Regards,
Kreutz.
Old 08-19-2008, 01:02 PM
jcdammeyer is on a distinguished road
C21, C22, C25 and C26 and other issues
I've finally gotten around to assembly of the first HP-UHU and have made up some sheets with colour coding for easily locating where all the parts go. Once the first board is up, I'll scan them and post to make it easier for everyone else (and me for the other 3 boards).
There are a couple of problems though. I've downloaded several zips with component layouts. On one, the PCB is marked Rev 0.10b while the green Rev00c 08/2007 component layout doesn't match the board. Instead I've been using the monochrome Rev 1.00 12/2007. However, it's missing R46 right by J7.
Next, the component list has C21 etc. listed as using a 5.1X3.2 footprint but in fact the caps on the board are on 0.1" spacing. What is the part # (or is there one) of the 0.22uFd MKT capacitor that fits this?
Any chance that an up to date version of the component overlay for the PCB marked 0.10b can be posted. Then I can transfer my coloured marks and labels it it along with Digikey and Newark part #'s.
John Dammeyer
Old 08-19-2008, 01:57 PM
Originally Posted by jcdammeyer View Post
John Dammeyer
Here is the component layout, later I will look around for the capacitor's part number.
Regards,
Kreutz.
Old 08-19-2008, 02:09 PM
Regards,
Kreutz.
Thanks. BTW, I have installed the 2200pF caps on the differential encoder SN75115 interface. I will investigate this O error problem.
John
Old 08-19-2008, 02:57 PM
Capacitor: http://parts.digikey.com/1/parts/843...014d0224k.html
  #11   Ban this user!
Old 08-19-2008, 04:42 PM
So you are saying just take the 0.2" (5.08mm) spacing part and bend the leads inwards to fit into the 0.1" (2.56mm) spaced holes? Kinda figured this was a layout error. ;-)
Curious as to why the component list has the footprint as 5mm.
John
  #12   Ban this user!
Old 08-19-2008, 07:20 PM
John
The component was listed as 5.08 mm on my Altium DXP2004 library but the footprint was wrong. Will be corrected on the next revision of the pcb (not scheduled yet)...
New Machine Build- My parts list - would like opinion haku DIY-CNC Router Table Machines 7 03-14-2008 07:04 PM
A little lost... How does this X2 conversion parts list look? JMcDonald Benchtop Machines 18 05-27-2007 08:04 AM
Fanuc 10 parts list needed curtisturner Fanuc 6 09-23-2006 12:36 PM
Haas parts list rattlesnake363 Haas Mills 0 08-10-2005 10:38 PM
DigiKey Parts List for v2.1 board ranman PicStep Controllers 0 05-27-2005 02:58 PM
