This thread shall discuss Power Supplies for UHU both HP and regular - and the regenerative dump circuits. This thread will include posting of circuit schematics / calculations / diagrams and recomendations. |
Hi Folks lets start this thread with my problems on the power supply end First here is the list of parts going into the PS 1. 220V primary and 78V 20 AMPS secondary toroidal transformer (gives 110V after conversion to DC) 2. 50 AMPS Bridge mounted on Alu heatsink 3. 5x 5000uF 150V electrolytic caps connected in parallel to give 25000uF 4. 5x 1uF 400V film capacitors connected at the electrolytic capacitor terminals 5. 2x 1k 20W wire wound resistors - wired in series to get 2K 20 W (used as bleeder resistors) 6. Regenerative dump circuit (Henrik Design) 7. 3x Fuses 8 amps cartridge. the problem: When I connect the powersupply transformer to the mains, the phase fuse in the main's blows, I see the fuse has only 4 to 6 strands of thin copper wire in it. I replace it and then go in for thicker wire on the fuses. then i connect again and again the fuses in the main switch blow. again there are only four copper strands connecting them, I thicken them to like 10 to 15 strands, then I connect the PS again, now the fuse (8 amps cartridge) just before the HP UHU blows, and immediately the Bridge rectifier burns out. This time the phase fuse in the electric pole outside is gone, the 32 amps MCB did not kick in!!!! This is what I am assuming : the toroid has a high inrush current at the start: how much can that be? is that causing the fuses to burn out? am I using wrong components anywhere? what is the right way to check the PS step by step? are there any extra components I need to add to the PS for safety concerns? find the photos attached! this problem is giving me nightmares - kindly help me solve it. RGDS Irfan |
| iRFAN..cHECK AT mECHMATE FORUM OR CALL pMINMO ...HE WILL HELP YOU....I hope the problem will be resolved by just getting outside and grab some electrician (not electrical engineer) who have many year of experience tackling such problems... I think i saw somewhere Hight value capacitor being added at power supply...I don't know the exact reason... Hope you will come up the problem soon, i saw the video machine is little slower with less voltages to servos...I hope you will get enough power to run at 200IPM... Best of luck |
| Your problem is most certainly a defective component or mis-wiring, The normal off load inrush should not cause the effect you are seeing, even with Caps connected. The recommended method of trouble shooting this kind of problem is to isolate sections at a time and power up as you go. IOW, first power up the Toroid with the secondaries open, then connect the Bridge with caps out of circuit, most often you are going to find a bridge connected wrong/shorted or a wrong connection somewhere, the secret is methodical trouble shooting. I haven't seen re-wireable fuses for decades. The size of fuse you have there would supply a welder! Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
![]() That sort of things run most of the industrial (small ) shops here and thats where we are. I will replace all fuses with D-types once everything is running. I am going to have a stick welder soon too. and yup........will do the PS installation step by step religiously this time. Thanks for the inputs Al |
| Hi contactirfu, You have a few electric boards directly against the wooden plate. If one of the boards gets hot because of a defect, the risk of fire is then bigger. I would use distance tubes to make a distance between the boards and the wooden plate, which would reduce the risk of fire. Although i would use a metal plate instead of wood in the first place. Vroemm. (Hmm, fun, writing in the new uhu forum :-) ) |
#10
| A 2 KOhm 40Watt resistor as a regenerative energy dump load is not going to be effective. As soon as I have some time, I will post the required calculation steps for the right resistor value. I would follow Al's procedure as the right troubleshooting procedure. Kreutz. |
#11
LOL, I am gonna take those things out! but not before all 3 axis are running.( Hylam - http://www.bakelitehylam.com/indlamni.html ) The whole controller was built by me and my Dad, the whole Sourcing task done by me, and dad handling the logistics for me. and YUP you are right on the resistor side - being a mechanical engineer has its disadvantages ![]() Kreutz thanks for help on this one. hope you can make your calculations sooner, it will help most people out here. RGDS IRfan Last edited by contactirfu; 07-02-2008 at 12:59 AM. |
#12
| Meanwhile one of the zone friend Manjeet suggest to me that If I use a switch between the Servo boards and the power supply after the capacitors then there will be an open secondary and I can have a delayed switching after the surge has stabilized, so I am going to have a DPST switch rated 20 amps in between the UHU servo power supply and the UHU boards. In future I will use a delay switch to switch on the PS for the UHU - hope it works! |
| How many power supplies?? | biotech1 | General Electronics Discussion | 1 | 02-07-2007 08:13 AM |
| power supplies. | LeeWay | Gecko Drives | 5 | 05-19-2006 06:17 AM |
| power supplies | itsme | Xylotex | 5 | 02-21-2005 01:40 PM |
| I need some help on Power Supplies. | Tasos_Eco | General Electronics Discussion | 5 | 02-07-2005 02:36 PM |
| Power supplies | CNCadmin | General Electronics Discussion | 22 | 07-16-2003 10:41 PM |
