Page 1 of 4 1234 LastLast
Results 1 to 12 of 39
Thread: High Power UHU Thread (HP.UHU)
    Jan 2005
    India
    Hi Folks,
    Just thought the we have different threads under the UHU thread so here it is.
    The HP UHU thread
    Mar 2008
    england
    hello to all,
    just been testing my board with motor and power for the first time,
    no smoke yet! but i can't get the motor to stabilise.
    when i switch the motor power on, the motor starts to run,if i do a reset the motor stops, then when i turn the shaft i can feel strong torque in one direction,but then the motor runs in opposite direction.
    after 3 hrs of adjusting the p.i.d the closest i have come,is to have the
    shaft stationary,but only torque in one direction.
    The motor power 40v.
    motor 70v 5amps with standard encoder conected to PINS A-6 B-4 ON J4.
    JUST SPOTTED! SHOULD BE =A pin 5 ,B PIN 3.
    is this my problem or is there something else.
    can you please help. Regards, Mick.
    Nov 2006
    HUNGARY
    Quote Originally Posted by mick22 View Post
    hello to all,
    Hi Mick,
    as far as I remember I had also some problem using HEDS standard encoder with the SN75115N differential encoder, so I simple took it out an I put two wire 'jumper' into the Ic shocket for the A and B signal...
    And please check the old thred :
    DIY Servo controller
    especially : #1890 05-01-2008, 06:14 AM tenmetalman
    the partlists includes the latest changes regarding values some component...
    I hope that helps ...Best regards,
    Jozsef
    Mar 2008
    england
    Quote Originally Posted by HJozsi View Post
    Hi Mick,
    Jozsef
    Jozsef,
    thanks for your reply,
    i tried removing the SN75115N and fitting jumpers,but still can't get
    the shaft stationary with torque in both directions.
    regards,
    mick.
    H.O
    H.O is offline
    Jul 2007
    Sweden
    Hi Mick,
    You say you have torque in one direction only. Is it completely "dead" in the other direction or do you have "some" torque but not as much as in the first direction?
    I ask because I've expereinced both problems... ;-) At first I had no torque at all in one direction, this turned out to be a fabrication error on the PCB which resulted in the gate-drive signals being shorted to ground for one of the MOSFETs. There's more info in the old thread.
    Then I had the problem with different torque depending on direction and this was cuased by the current limit circuit triggering due to noice, increasing C29 from 100pF to 470pF cured it on my test drive.
    If you have a scope, look at the PWM output from the UHU-processor to see if it "tries" to apply torque in both directions, then look at the outputs from both IR21844 driver chips and see if you have drive signals to the MOSFETs.
    HTH
    /Henrik.
    Mar 2008
    england
    Quote Originally Posted by H.O View Post
    Hi Mick,
    HTH
    /Henrik.
    hello Henrik,
    no it is not completely dead, infact it is possible to get torque in
    both directions,but not when the settings have been adjusted to make the
    rotor stop after a reset.
    i have had a situation where reseting toggles the direction of rotation.
    no i dont have a scope.
    thanks, mick
    Henrik,
    there are no step and dir signals connected yet,could this have
    anything to do with it.
    regards.
    Jan 2005
    India
    are you using the Gxxx for moving the motor, then even I find that sometimes the motor does not move, I think its programmed to behave that way!
    well try connecting the step and direction signals and the motor will turn.
    RGDS
    Irfan
    Mar 2008
    england
    Quote Originally Posted by contactirfu View Post
    RGDS
    Irfan
    thanks Irfan,
    my problem is getting the rotor to stop, with torque in both
    directions.
    regards, mick.
    Aug 2006
    thanks Irfan,
    directions.
    regards, mick.
    Hello;
    If the rotor moves in the wrong direction when applying torque, you should reverse the motor cables. If it oscillates around the rest position you should work on the motor tuning (PID). If it moves in both directions but does not stop, it is getting noise on the step/dir signals, there is a problem with the encoder signals, or there is a problem with the output stage Mosfet driving, as pointed out by Henrik.
    Regards,
    Kreutz.
    Mar 2008
    england
    Quote Originally Posted by kreutz View Post
    Hello;
    Regards,
    Kreutz.
    Kreutz,
    many thanks for pointing me in the right direction,
    all i have to do now is find the courage to mess with the board.
    cheers, mick.
    Mar 2008
    england
    Hello to all,
    after my partial success with this board i have smoked the
    output , luck'ily the board is ok, now i'm back to reading the old posts.
    could someone please tell me, how important is height of R37,R36,R29 &R23
    above the board surface, mine are way below .15",could this be my trouble.?
    regards mick.
    ps
    i'm now the proud owner of a scope,so maybe will be able to stop the smoke!,
    Nov 2006
    HUNGARY
    Wink
    regards mick.
    Hi Mick,
    regarding my experience, it is more important the proper current limit...
    regards,
    Jozsi
  • Page 1 of 4 1234 LastLast
    1. High voltage & high power servo drive design
      By Xerxes in forum Granite Devices
      Last Post: 08-22-2008, 10:24 PM
    2. Replies: 7
      Last Post: 04-15-2008, 05:27 AM
    3. High Torque , High Bandwidth Motor or Servo
      By mastabib in forum Benchtop Machines
      Last Post: 09-26-2007, 03:09 AM
    4. Power Supply for High Amps
      By bprzybyl in forum General Electronics Discussion
      Last Post: 02-24-2007, 03:01 PM
    5. Power supply voltage too high
      By spoiledbrat in forum General Electronics Discussion
      Last Post: 06-13-2005, 10:39 PM
