Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 12-19-2010, 09:28 AM
visky is on a distinguished road
Unhappy board problem
I made my own board with uhu servocontroller and have to fix one problem. when i connect pc and board i dont get parameters or are shown but are mixed with symbols ( leters and symbols ) (:
What could be wrong? Capacitors across rs232 , 10uF 100V or 27pF capacitor on xtal, anything else?
ID:	121748   Click image for larger version
Old 01-03-2011, 02:55 AM
LZ1TWB's Avatar
LZ1TWB is on a distinguished road
Have you checked that everything is connected right? If so, the check it again. That's what I do when something doesn't work.
Also try with a different Xtal. If you got it from Uli then you should not have problems, but if you purchased it yourself it will not always be suitable. It should be first order, because some Xtals say 24Mhz, but they are actually 8's working in 3'rd order mode. I guess the schematic is different then.
From the board I see less tnan usual elements. Is this only the processor part, and the power section is supposed to be on another board?
Happy new year,
Todor
Need Help!- Help me diagnose a problem with my board (or PC) eran k Stepper Motors and Drives 0 04-09-2010 02:03 AM
Odd problem with c10 BO board binfordw Benchtop Machines 3 01-23-2010 02:02 PM
problem with ram board diegobertoli Fanuc 0 01-30-2009 02:11 PM
stepmaster board possible problem??? sintratech Controller Cards 9 06-10-2007 03:08 PM
I/O board problem squarewave CamSoft Products 16 10-28-2004 11:00 PM
