Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > UHU Servo Controllers
Old 04-10-2010, 03:25 PM
dfv dfv is offline
dfv is on a distinguished road
ENCODER AMT102 PROBLEM
i have the old UHU boards that were working good with my dc motors+optical encoders. But today I removed the optical encoders and put a new AMT102(set with 500ppr), then i switched on my machine and tried to move one motor axis to check if the motor try to keep its position and in found that in the clockwise direction the motor works good (don´t let me turn the axis) but when i turned in the opposite direction the motor began to run without control. Then I swap chA and chB, and happen exactly the same but in the oppsite directions: in counterclockwise works good (mantein its position) but in clockwise run without control.
The encoder cables (5V,chA,chB,0V) are properly connected to the UHU board and the index pulse is not connected (it is free).
Anyone know what is happen? is neccesary to change in the old UHU board some components to work with the AMT102?
Old 04-10-2010, 04:19 PM
Al_The_Man's Avatar
With a single ended output, it sounds like you have one channel and the marker connected instead of A & B?
Old 04-10-2010, 05:36 PM
dfv dfv is offline
i have checked, it is connected chA and chB.
Old 04-10-2010, 07:26 PM
dfv dfv is offline
Problem solved, you were right, cables were bad connected. Thanks.
Need Help!- DMC 70V Encoder problem leike Deckel, Maho, Aciera, Abene Mills 12 03-23-2010 08:05 PM
Need Help!- 4th Axis encoder problem? Scanfab Fadal 7 04-23-2009 06:18 PM
Bridgeport 760 t16 encoder problem jke6113 Bridgeport and Hardinge Mills 1 09-28-2008 07:36 PM
Encoder problem? paulend Servo Motors and Drives 5 02-06-2007 09:01 AM
Encoder problem? pauls Industrial Hobbies (Support forum) 11 12-16-2006 06:51 PM
