Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 12-18-2009, 11:28 AM
encarlisle is on a distinguished road
sheet body tool paths
I'm cutting a series of sheet body parts created in solidworks. What i've been doing so far with mixed results is importing the model dis assembling it down to what i need to cut then mirroring the sheet bodies, creating the trimmed surface seen in the attachment. I use cavity mill to rough with no problems however when I use area mll to finish the surfaces i get weird random gouges on the part when i used z level on this particular part it came out good. i'm using cam general set up and setting it up as workpeice rather than mcs mill.
can anybody help me with workflow or any pointers on what would be causing these problems?
Name:	trimmed sheet 2.jpg‎
Old 12-21-2009, 03:45 PM
markrief is on a distinguished road
Check the topology of the part geometry. After all the importing and mirroring, you may have to unify all the material side vectors.
Mark Rief
Siemens PLM
Newbie- Creating tool paths CNCMike Mastercam 4 04-15-2008 03:38 PM
offsets for tool paths acidcustom Autodesk Software (Autocad, Inventor etc) 14 05-30-2007 02:35 AM
Rotary tool paths DAB_Design Mastercam 1 03-31-2005 01:27 PM
3d tool paths ginamc OneCNC 5 03-19-2005 11:17 AM
Tool Paths WOODKNACK G-Code Programing 7 04-26-2003 08:09 PM
