Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 11-04-2009, 09:55 AM
weirdharold's Avatar
weirdharold is on a distinguished road
Which Tool Path ?
I need to tool path this part in order to check my "A" axis rotation on my 4 th axis post I am buildng with PB. I have tried "contour area" with no luck. Thank's for any help .
Regard's,
Harold C.
Old 11-18-2009, 12:55 PM
camster is on a distinguished road
Harold,
You need to us a multi-axis operation. I would use surface area or streamline as the drive method and select the floor face of the slot as the cut area. Set the tool axis to normal to drive and the projection vector to toward line, using two points at the center of rotation. This should give you A axis rotation.
What version of NX are you using?
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
Old 11-19-2009, 09:47 AM
Variable Contour ?
That is tool path I used to get tool to follow the path of the groove. The other's you mentioned,surface area or streamline , produced weird result's, due to the lack of my understanding how to use them. I don't understand the part about "using two points at the center of rotation. " Do you mean picking a point at the center of the part at each end ? Excuse my lack of understanding . Thank's.
Harold C.
Old 11-19-2009, 02:36 PM
In NX the Tool Axis and Projection vector work togeter to get the correct motion. When you set the Projection Vector to Toward line one of the options is two points. So yes pick a point at the center of the part at each end.
You can e-mail me the file and I can take a look.
Old 11-24-2009, 09:16 AM
Smile Thank's for looking at this !!
All your time greatly appreciated. One last question. After you get one tool path, what would be the most efficient way to do the 7 other groove's ? Transform the tool path's & re select the geometry or maybe another way ??
Regard's ,
Harold C.
Old 11-24-2009, 12:07 PM
Tool Paths
I would transform them.
Depending on the machine it may be better to use a sub program. But getting that to work with Post Builder requires some customization and Tcl.
Need Help!- can't get the tool path right msn_jrd Mastercam 3 07-21-2008 11:43 AM
3-D TOOL PATH reedmiles BobCad-Cam 15 02-02-2008 08:08 PM
Tool Path cijunet Mastercam 9 11-26-2007 10:17 AM
Tool approach Tool Path Kiwi BobCad-Cam 28 07-05-2007 03:35 AM
Tool Path WOODKNACK TurboCAD/CAM 4 06-27-2003 08:27 AM
