| UG NX UG CAD/CAM Discussion |
| cavity milling nx6 i am having trouble getting cavity milling rough and finish to machine all the way to the bottom of curved pockets the cutter is small enough and ball nosed and the cut level is sufficiently deep whats going on? if roughing with 1/2 ballnose finishing with 1/4 ballnose what would be the best strategy? rounds are 1.8 inches wide and .9 deep it does not finish to depth.forklegs3_sldprt.zip |
| NX6 Cavity Milling I have found that using a mill area of only the faces I want to cut works much better with cavity milling. You don't have to screw around setting the depth ranges and it just works better. I also use the level based IPW so the next tool only cuts the remaining material left from the previous operation. See the attached part
__________________ John Joyce -NC Programming Supervisor Barnes Aerospace, Windsor CT |
| Cavity mill is strictly a z-level operation, in other words 2 1/2 d, and will not follow a curved surface at the bottom of the cavity. Use Cavity mill to rough and a mill area operation to finish. |
| Need Help!- v22 mold cavity help | chromic20 | BobCad-Cam | 2 | 09-23-2008 06:07 PM |
| Need Help!- Cutting 2 different tapers in cavity | erock777 | BobCad-Cam | 1 | 09-10-2008 04:26 PM |
| Need Help!- create mold cavity | Rob 1264 | SolidEdge | 0 | 05-09-2008 12:04 PM |
| Mold cavity | kojack | MadCAM | 1 | 11-01-2007 03:22 PM |
| Creating a hollow cavity | partsman | General Metalwork Discussion | 3 | 11-09-2006 10:58 AM |
