Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 06-02-2009, 05:17 AM
NCexplorer is on a distinguished road
clamp and unclamp AB axis in PB command
I have created a 5 axis AB table machine, and its post.It works now until the real machine in workshop, but for clamp and unclamp command still didnt found, for now I manually insert it in G-code.
I saw in UDE there is CLAMP command in NX6, but it need to put the custom commmand(clamp) in POST BUiLDER, and I still finding the way.
Someone here have successfully using clamp, please tell me to e-mail:
maryadister@gmail.com
Maryadi
Appl Engineer.
NSI- Jakarta
Indonesia.
Old 06-04-2009, 07:00 PM
camster is on a distinguished road
In NX you can add the Clamp UDE and set it to Auto. Then in Post Builder look in the custom commands for the 4th and 5th axis clamp commands and edit them to output the correct codes. This should output the codes when the 4th or 5th axis moves. You can also use the UDE to manualy unclamp and clamp the axies.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
Old 06-09-2009, 10:53 PM
Thanks John,
It so easy with NX Postbuilder.
Tags
clamp
Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table automizer DIY-CNC Router Table Machines 10 11-02-2010 01:05 PM
Axis examination command kevinuk32 Cincinnati CNC 0 04-16-2009 04:32 AM
Looking for how to set Keyboard Command for Z axis LockTech Machines running Mach Software 5 05-14-2008 11:13 AM
Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table automizer Work Fixtures and Hold-Down Solutions 0 04-07-2008 10:05 PM
Spindle Tool Clamp/Unclamp Alarm Q12321 Machine Problems, Solutions , Wireless DNC, serial port 2 10-10-2006 04:24 PM
