Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 04-27-2009, 03:25 PM
tarponicus is on a distinguished road
5 axis compensation
Hi all,
anyone know how to pull a surface vector/normal into a post for compensation directions w/ a 5-axis machine?
Thanx,
-Jerry
Old 04-27-2009, 04:42 PM
camster is on a distinguished road
Post Builder should be able to give you the information. In surface contouring, if you turn on contact output, you will get the
surface normals in the tool path for the post to use in 3D cutcom. Look at
the custom command
pb_cmd_three_dimensional_tool_offset.tcl for a Fanuc example.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
Old 04-28-2009, 08:43 PM
yep worked like a champ! Thanks Camster.
Need Help!- Z-Axis Backlash Compensation on a Mill carlosdcerna General Metal Working Machines 2 04-03-2009 06:17 AM
Compensation for axis drift? justrack LinuxCNC (formerly EMC2) 2 12-11-2008 06:05 PM
Fanuc 5 axis radius compensation d.a.v.e Fanuc 1 10-06-2008 03:52 AM
backlash compensation with slave axis jeb Mach Software (ArtSoft software) 2 03-04-2008 03:05 PM
