Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 04-20-2009, 07:01 AM
sjh sjh is offline
sjh is on a distinguished road
nx5 cam
hi,
how can i find nx help files?
Can i have polar coordinates in output gcode file?
sjh
Old 04-20-2009, 08:47 AM
camster is on a distinguished road
When NX is installed the help docs should be installed as well. Get then installed.
Yes you can have polar coordinates. What version of NX are you using?
One way is the use the User Defined Event "Set Polar" - then the post will need to be set to output polar coordinates.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
