Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 03-19-2009, 08:51 AM
encarlisle is on a distinguished road
trim solid body
what i want to do is trim the revolved body and keep whats in the piece of pie the trim curve is created in an offset plane and has also been projected on to the faces that make up the body help what am i doing wrong?
Old 03-19-2009, 11:43 PM
blmmdes is on a distinguished road
Sorry.. encarlisle...i didnt get you? you want to trim a solid with a curve? if yes, then you can do it in NX.
To trim a solid body you need another body(sheet or solid). so create a extrude surface from your curves and then trim the solid.
Ananth Kulkarni
THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
les paul solid body stukent Musical Instrument Design & Construction 260 10-14-2009 05:25 PM
Need Help!- Ibanez jem 77 solid body rockerfx Musical Instrument Design & Construction 2 07-10-2008 07:07 AM
Solid Extrude Cut Body Mastercam User Mastercam 2 12-01-2007 11:48 AM
Trim john_mccarron EdgeCam 3 11-27-2007 07:42 PM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 07:25 AM
