| UG NX UG CAD/CAM Discussion |
| surface creation I have model ( for learning only ) that has half -holes , that I would like to know how to fill , so I can create tool-path's on this area. Have tried with a few different method's of surfacing with no luck . If anyone could point me in the right direction, I would be grateful. Area I wan't to fill is circled in image. Thank's in advance. Harold C. |
| Try Edit>Face>Delete Face option and select both half-circular and the bottom flat face. If it doesnt work you can Extract the adjoining surfaces and use Edit Sheet Boundary>Remove Trim option. This will give you the original suface and you have to trim them to fill the open area. If i am not clear enough please post back.
__________________ Ananth Kulkarni THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND |
| Third way....Model complexity dependent Since this seems like a pretty easy and straight forward model, you can also create Ruled surfaces between the edges, I use Arc Length option instead of Parameters by removing the Preserve Shape checkmark
| Harold, In NX5 you can use Direct Modeling to delete the faces. Select Insert - Direct Modeling - delete Face. Then Pick the faces of the "hole" The system will extend the remaining faces to cover the area removed.
__________________ John Joyce -NC Programming Supervisor Barnes Aerospace, Windsor CT |
| Thank's Ananth for your tip. That worked great. Thank's also John for your input. Tried the Direct Modeling to delete faces, but all I got was error box that said ( It was not possible to delete the set of faces to be removed. ) This is a Parasolid Text File. X_T. Don't know if this has any thing to do with not being able to perform this function. But as alway's. thank's for your time. Harold C. |
| Need Help!- 3D wireframe creation | brockadeau | BobCad-Cam | 19 | 01-31-2008 09:42 PM |
| Surface Creation Help | stevespo | BobCad-Cam | 3 | 05-17-2007 05:55 PM |
| Airplane creation | Atomik Rooster | Solidworks | 14 | 12-27-2006 01:30 PM |
| My digital creation ( Nothing to do with CNC) | ynneb | CNCzone Club House | 9 | 02-08-2006 10:57 PM |
| Image Creation | rweatherly | Coding | 1 | 11-18-2005 12:00 PM |
