Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 02-15-2009, 06:22 PM
tarponicus is on a distinguished road
controlling rotary axes
Anyone have a good way to control rotary output order? I have some holes to drill on opposite faces of a part. I prefer to only index the B 180 so that the hole positions remain constant instead of indexing A 180. The posted code comes out as A180.
Old 02-16-2009, 09:46 AM
camster is on a distinguished road
You should be able to use the Lock Axis UDE.
Lock the A Axis. This way the post should force the B axis to move. You may need to chage the Lock plane to get the correct output.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
Need Help!- Controlling the L297+L298HN with PIC CyberArtem PIC Programing / Design 0 12-26-2008 09:56 PM
Rotary Axes help needed watchman General CNC (Mill and Lathe) Control Software (NC) 0 05-17-2007 04:13 AM
Controlling feed rate... saturnnights Machines running Mach Software 3 04-01-2006 10:18 AM
Help with controlling CNC! Kammo1 Stepper Motors and Drives 2 06-11-2005 03:54 PM
controlling x axis mikejkd DIY-CNC Router Table Machines 0 05-17-2005 10:19 PM
