| UG NX UG CAD/CAM Discussion |
| Hi, we just made the switch to NX6 (from 5). I'm not sure about NX4, but you can switch back to the "Mating Conditions" you see in version 5 by selecting the following from the top menu bar in NX: -Preferences -Assemblies -In the "Assembly Preferences" box that pops up, in the bottom pulldown box called "Interactions" you can select between "Assembly Constraints" (new) and "Mating Conditions" (old). I have not figured out how to keep theese settings when you exit out and come back into NX, so I have to remember to set it every time. Hope this helps.
__________________ It is the poor craftsman that blames the tool |
| You can set the preference under the customer defaults File - Utilities - customer defaults Select the Assemblies section - Extras - You can use assembly constraints or Mating Conditions. I would suggest using Assembly constraints. You can convert your existing assemblly mating conditions to assembly constraints. they are not hard to use. Read the help doc's The best way to see the constraints is 1. Make sure the constraints display option is active on the assembly navigator. Right click in an empty area of the Assy Navigator and make sure the Include Constraints option is active. 2. When you select a component and want to see it's constraints expand the dependencies panel at the bottom of the navigator and click on details, the magnifying glass.
__________________ John Joyce -NC Programming Supervisor Barnes Aerospace, Windsor CT |
| Problem- Need help with assembly please | dpark1 | Solidworks | 2 | 07-26-2008 10:43 AM |
| Re-assembly of X-2??????? | Smitty911 | Benchtop Machines | 5 | 07-13-2007 06:16 PM |
| Z axis assembly | xlukkajr | DIY-CNC Router Table Machines | 5 | 10-19-2006 02:21 PM |
| jgro assembly | drfoz | JGRO Router Table Design | 1 | 09-06-2006 07:50 PM |
