Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 01-19-2009, 01:09 AM
weirdharold's Avatar
weirdharold is on a distinguished road
Smile To Be or not To Be in Inches
I know where to set Default Unit's to Inches to be in that unit of measurement, In Customer Default's . I would like to know where to change a model that I bring in, that's metric , to inches. Thank's in advance . Harold C.
Old 01-19-2009, 10:45 AM
camster is on a distinguished road
Converting part files
You need to run ug_convert_part.exe. It cannot be converted from within UG. The ug_convert_part program must be run from the command prompt. I would suggest reading the help docs on this topic.
Attached, I hope, is a program that you can also use.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
Old 01-19-2009, 01:06 PM
SnakeD0ct0r is on a distinguished road
Thumbs up Use Master Model
Converting the file is not necessary the best way of doing this. It is better to create a new inch part file for manufacturing, then assemble the component into it. This is called Master Model, even though your part is MM, since you assemble it into an inch part file, you now can work in inches. If you convert the units, then work on it, and there are any changes, you will have to modify each and every part file that you have an operation programmed for, if you assmble it in, and a modify is needed, change it once in the master model, and all down stream apps will update.
Old 01-20-2009, 09:20 AM
Another issue to be aware of is when you convert the file the expressions are still in the units you had specified. The model will still be the same size.
Old 01-22-2009, 10:30 AM
Smile Thank's
Thank's John for the program & tip's. And you too SnakeD0ct0r. I will keep all of this in mind . I have yet to deal with assemblies. We mainly deal with one part per file. We bring in files from the designer, modify it , if needed , & make tool-path's.
Harold C.
Inches and mm jorgehrr Solidworks 8 02-04-2008 04:43 PM
Metric mm or Imperial inches? Please help. alexccmeister Benchtop Machines 14 02-21-2007 09:19 PM
inches per minute planescott Mach Software (ArtSoft software) 7 02-24-2006 07:29 PM
Inches / Minute in Aluminum rcazwillis General Metalwork Discussion 7 04-06-2005 08:15 PM
Mach2, pulses per sec, inches per min Bloy2004 Mach Software (ArtSoft software) 6 11-16-2004 07:56 AM
