Results 1 to 6 of 6
Thread: Problem with linked feature
    *Registered User*
    Sep 2008
    India
    I am facing problem with linked feature.
    When I am using wave geometry linker to take link from one assembly part (say Part-1) into another (say Part-2) and change the original feature in Part-1, the linked feature in Part-2 remains un-updated or get failed and feature created in Part-2 with the help of linked geometry remains un-updated or get failed along with all related features, then I have to update the linked feature separately in Part-2 in assembly and unsuppress the related features.
    How can I solve this problem?
    Feb 2006
    What version of NX are you using?
    Are Part-1 and Part-2 in the same assembly? If not then they will not update unless Both files are open when you make the change.
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    *Registered User*
    Sep 2008
    India
    I am using nx-4.
    Yes, Part-1 and Part-2 both are in the same assly.
    Feb 2006
    Without the actual model is is difficult to understand the problem. Are you sure the delay interpart update is not active? Tools - update - delay interpart
    *Registered User*
    Sep 2008
    India
    Yes, Delay Interpart not active.
    Feb 2006
    Make sure your load options are set to load interpart data as well.
    1. feature cam to dxf
      By daleman in forum FeatureCAM CAD/CAM
      Last Post: 07-15-2011, 09:59 AM
    2. Artcam Feature problem
      By djh82uk in forum ArtCam Pro
      Last Post: 01-16-2008, 05:19 PM
    3. feature cam problem
      By MarshCustom in forum FeatureCAM CAD/CAM
      Last Post: 01-14-2008, 03:55 PM
    4. paperclip on direct linked pictures
      By sendkeys in forum Suggestions for the CNCzone.com site.
      Last Post: 01-18-2005, 02:21 PM
    5. Linked Cable/wire Guides ????
      By frinkdaddy in forum General Electronics Discussion
      Last Post: 10-25-2004, 04:44 AM
