| UG NX UG CAD/CAM Discussion |
| Background Color This is not a big problem, but I would like to know the correct step's & where to make them stick or be my new default background color, in Modeling & Sketcher. Every time I open a session of NX5, my background color revert's to the light blue. I prefer black. I know I can go to Preferences/Visualization/ & the Visualizatoin Preferences dialog box appear's & edit background & change it to the color I want. But if I close out NX5 & start a new file it revert's back to the hard to see blue background. I know it's a setting somewhere , but I can;t find it . Very Annoying. Thank's for any help in advance. Harold C. |
| Use seedpart I use a seedpart. Along with black background i have my layer categories, object preferences etc defined in it. I added a new button and pointed (thru marco)it to this file. so every time i hit create a new part it creates a copy of my seedpart. Although i would be more than interested to know if any other way to do it. Regards,
__________________ Ananth Kulkarni THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND |
| You can also set up a Visualization Template that you can drag and drop onto your current part file and set the background colors as well as other visualization settings. Check the help docs on Create visualization settings template.
__________________ John Joyce -NC Programming Supervisor Barnes Aerospace, Windsor CT |
| You can change in the customerdefaults: gateway>visualization>background (tab) I have the default graduated blu background for shaded view and a black background fore the wireframe view. I really like, especially with the radial popup up & down for switching between views. |
| As 850T3 explained, you can change this, and just about any other default from customer defaults. You can get to this from File -> Utilities -> Customer Defaults. You are better off changing here then using a seed file. Customer defaults can be exported out of one version then imported into the next. Although you can use a NX5 seed file in NX6, you will not get the template changes from the newer version. The Customer Defaults can be set from company standard to a goup level, or at a user level. |
| Need Help!- Background bitmap? | THend | Mastercam | 2 | 05-31-2008 05:33 PM |
| background in artcam | menewfy | ArtCam Pro | 6 | 07-24-2007 02:35 AM |
| Autocad : Put a jpeg in the background to copy it? | civilseal | General CAM Discussion | 2 | 04-08-2007 09:56 AM |
| Going 3D from a 2D AutoCAD background... Rhino? SW? BobCAD? | InspirationTool | General CAM Discussion | 7 | 09-29-2005 01:17 PM |
| light grey background color | koslaz | Suggestions for the CNCzone.com site. | 0 | 08-08-2005 04:42 PM |
