Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 09-19-2008, 02:12 AM
*Registered User*
sk96_me45 is on a distinguished road
Blen All Instances not working
Dear Friends,
When I use edge blend command I have to select all edges one by one of same feature even I had already toggled on the option "Blend All Instances".
Old 10-02-2008, 08:53 AM
camster is on a distinguished road
What version of NX are you using?
Th Blend all instances is used when you have created an array of features and then apply a blend to one of them, it get applied to them all.
Check your selection intent options and use tangent curves or all in face.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
Old 10-03-2008, 01:28 AM
*Registered User*
I am using nx4.
what u said is OK, but suppose if I created a rectangular feature and I want to give blend on all four edges with a single edge selection then what should I do?
Old 10-06-2008, 06:43 AM
blmmdes is on a distinguished road
Use body edges from the selection intent
Ananth Kulkarni
THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
Newbie- Don't know what I need to get this working, need help! leirpytt General Electronics Discussion 6 04-13-2008 03:41 PM
Trying to get my x2 CNC working... TheWolf Benchtop Machines 14 03-26-2008 10:27 PM
Working with MDF Miguelflores General Material Machining Solutions 9 03-16-2008 05:45 AM
She was working utengineer04 Bridgeport and Hardinge Mills 1 07-25-2005 10:39 PM
Not working well. ihkim Servo Motors and Drives 3 05-23-2005 06:32 PM
