Results 1 to 2 of 2
Thread: Cant select surface for 4 axis Wire edm
    Feb 2008
    For some reason it wont let me select the surface to do a 4 axis wire edm operation.
    I tried to enlarge the surface but no luck. I attached the file. It is the triangle
    looking surface I need to cut. I had to WAVE geometry linker to create the surface(becuase it is a tube), any problems there?
    Any ideas why??
    I am using NX6 and NX4 and both versions same problem.
    Attached Files Attached Files
    Registered Brewmeister's Avatar
    Oct 2007
    The Wire application is fickle about things being neat. (rectangular & parallel to the machine).
    Your best bet is to create some lines surrounding the area to cut.
    Then use the 4-Axis, Wireframe option in Open Profile,
    and only select the bottom line. It will find the sides & top.
    Select the end where you want the path to start.
    Set the top & bottom plane in Cutting Parameters to define where
    the output points are generated.
    Hope that helps
    "Of course, that's just my opinion. I could be wrong!"
    T Briggs (CAM dude) - Siemens PLM Software
  1. 4 Axis Wire EDM Application
    By squarewave in forum CamSoft Products
    Last Post: 09-30-2008, 11:18 AM
  2. Hot Wire for 3 axis CNC
    By huntycnc in forum CNC Wire Foam Cutter Machines
    Last Post: 10-19-2007, 06:32 PM
  3. Replies: 19
    Last Post: 09-18-2007, 08:48 PM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 03:58 PM
  5. selecting wire frame or surface?
    By fastolds in forum Surfcam
    Last Post: 01-04-2005, 02:29 PM
