Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 09-05-2008, 02:26 AM
blmmdes is on a distinguished road
Import stp file in NX
Hello,
Never thought about this one before.
I have a assembly file exported from Inventor as a stp file. In normal course if i import that file into NX it will create all the parts and maintains the assembly structure as well.
But all the new NX parts are created using default NX part template.
What i want is to configure is that the new parts use my standard part template(seedpart) instead of standard NX part template.
I am using Nx4.
Regards
Ananth Kulkarni
THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
Old 09-08-2008, 12:11 PM
Brewmeister's Avatar
Brewmeister is on a distinguished road
Ananth,
If you look in the install directory for NX, there are 2 folders (STEP203UG, STEP214UG)
Look for NX part files in these folders (i.e. step214ugnullnx50_in.prt)
These are the 'seed' parts that get used when doing a translation.
If you replace the appropriate part with your own template part, it will use it as the seed part.
I would recommend backing up (rename to .bak) the supplied part before replacing it.
Be Well
"Of course, that's just my opinion. I could be wrong!"
T Briggs (CAM dude) - Siemens PLM Software
Old 09-10-2008, 10:40 PM
Thanks Brewmeister it works
Ananth Kulkarni
import .SAT file Tinmuk Surfcam 1 07-23-2007 05:28 PM
DXF-file import problem stmahe Dolphin CADCAM 1 04-12-2007 11:28 AM
file import(again) swarfmacdaddy TurboCNC 4 06-12-2005 08:57 AM
file import swarfmacdaddy TurboCNC 3 06-07-2005 03:01 AM
file import motomitch1 OneCNC 1 03-24-2005 10:08 PM
