Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 08-15-2008, 02:46 AM
blmmdes is on a distinguished road
Circular output in milling
Hi all, Using Nx4.
Please have a look at attached file. My part is perfect circle and i want to finish it by z-level profile option. But when i post the program what i get is a series of quadrant movements and not a full circle movement. The problem is i am getting a small recedue at the point where the quadrant movement ends. its not acceptable. is there any way that i can get a full circle movement. For your info in post my circular motion is set to FULL CIRCLE option.
I am pretty sure that this has something to do with LOOK AHEAD of the machine as well but i need a strong arguement to explain it to our workshop supervisor who believes the machines we have are the best.
Thanks and Regards
Ananth Kulkarni
THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
Old 08-15-2008, 03:29 AM
holbieone's Avatar
holbieone is on a distinguished road
is the cut smooth or does it pause at the quadrant points ?
if the cut is smooth what you are seeing is the backlash from the axis reversal at the quadrant point
Old 08-15-2008, 08:30 AM
Thanks for your comments.
Yes the cut is smooth. its not stopping at quadrant point.
Pardon me, if you can explain me about backlash from axis reversal? why it happens? because of old machine and worn out lead screw?
Ananth Kulkarni
Old 08-15-2008, 10:05 AM
holbieone's Avatar
yes a worn machine will have some backlash
what wears is the ballscrew assembly , the bearing blocks for the screw and the machine ways
on most machines you can compensate for the backlash
first you need to check the amount of backlash you have
use a 1 inch dial indicator mount it on the table parallel to an axis jog it to touch the spindle ,zero it out step in 0.01 ten times then step back ten times and compare the position of the indicator from the start
the difference will be the backlash for that axis ,do it several time to come up with an average
adjust the comp in the control and repeat for each axis
this will get rid of most the backlash
you will still see some dwell mark from the axis reversals but they should be less
also if you axis are belt driven the belts could be worn
Old 08-17-2008, 11:48 PM
I got an average value for backlash. How do i tell my controller about this? You said "adjust the comp in the control"
Where actually i can do this? and how
Ananth Kulkarni
Old 08-18-2008, 01:12 PM
holbieone's Avatar
what control do you have
Old 08-18-2008, 11:14 PM
FANUC
Ananth Kulkarni
Old 08-19-2008, 12:48 AM
holbieone's Avatar
you will have to ask someone that knows that control
sorry i can't help you with that
Old 08-19-2008, 01:02 AM
OK THANKS FOR THE HELP SO FAR
Ananth Kulkarni
Old 08-20-2008, 12:08 AM
*Registered*
COMMAND JOHN is on a distinguished road
FANUC
How much backlash do you have most of the time it will be in the thrust bearings.
What # Fanuc control do you have.
John
  #11   Ban this user!
Old 08-20-2008, 12:28 AM
springlakecnc is on a distinguished road
Command John is correct! most of the time the backlash IS in the thrust bearings. If you have anything over .0015 of backlash, you can't comp for it, and make your cut perfect, so say the hardcore mold cutters! put an indicator on the end of your ball screw and see if its moving, while you jog back and forth, that will tell you where the bear **** in the buckwheat....MY GOD, i'v been hanging out with old people to much!
  #12   Ban this user!
Old 08-21-2008, 06:30 AM
Its Dialog 11
Sorry friends,
Its not fanuc control its a Dialog11 from Grundig. I have a backlash of 0.015mm on X and Y axes. Now the question is how do i compensate for it in the controller? is there any parameter that needs to be changed? if yes, which parameter?
Thanks in Advance
Ananth Kulkarni
What do you know about this circular saw??? mailloux WoodWorking 5 10-16-2007 11:34 PM
mazak 640m circular tornado milling cycle magneto259 Mazak, Mitsubishi, Mazatrol 5 04-20-2007 01:03 PM
Circular Cut Sanghera GRZ Software- MeshCAM 13 11-13-2006 11:26 AM
Milling 37 degree chamfer around a circular piece... peter.blais General Metalwork Discussion 21 09-20-2006 01:47 PM
Circular Milling - G12/G13 HPT Servo Motors and Drives 6 05-14-2006 02:22 PM
