| UG NX UG CAD/CAM Discussion |
| 4 axis Are there any videos that show how Nx6 does true 4 axis milling? I would like to true sprial along a A axis odd shape cylinder if possible? Is there a software to specializes in 4 axis programming? Ex. Rotary dies and turbine blades? Thank You |
| Yes, NX6 is your answer. I will try to find you some videos. Please post a pic, a sketch or a file of the part you are talking about |
| Thanks Jeff. |
| Actually you can do this in earlier versions of NX. I have been doing it since NX2 in 5 axis simultaneous mode machining internal surfaces. |
| The “trick” to doing this is to place a cylinder around the model and use the cylindrical face as the drive surface. Make sure your projection vector and tool axis are correct. To get Spiral motion use the Helical cut pattern. This is a standard technique that has been around for a long time and works well.
__________________ John Joyce -NC Programming Supervisor Barnes Aerospace, Windsor CT |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 07:31 AM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 02:54 PM |
| One axis (z-axis?) computer controlled testing device | TsThorsell | Stepper Motors and Drives | 3 | 02-07-2008 01:38 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 03:58 PM |
