| UG NX UG CAD/CAM Discussion |
| MFG_Wire EDM_ARC OUTPUT Hi all, Using NX 4.0.3.3. Our Wirecut machine's RS232 interface stopped working for unknown reasons and i want to print out the G code file so that we can type manually on the controller untill the DNC problem is solved. I have a ceated a 4-axis wirecut program, the problem is the length of program (too many blocks) and I figured out that the program generated by NX is in point-point format and is not outputting the arcs. however my option under Start/End Events>Arc output is checked ON. It is not the problem of postprocessor either because i am using the default WIRE_EDM post provided by UGS by changing the output units to MM. The same post will output arcs in the case of a 2-axis program. i am attaching a sample file for your perusal. Please have a look and advice me. For your info the motion format for our machine is X Y I J U V K L (XYIJ being programming plane co-ordinates and UVKL being auxillaryplane co-ordinates) Thanks in advance
__________________ Ananth Kulkarni THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND |
| Ananth, I ran your part file through NX6 and this is the G-code I got: N0010 G00 G90 X-1.0775 Y-.0984 U.3165 V0.0 N0020 G42 G01 X-1.0869 Y-.0801 N0030 X-1.0942 Y-.0608 N0040 X-1.0996 Y-.0409 N0050 X-1.1028 Y-.0206 N0060 X-1.1039 Y0.0 N0070 X-1.1023 Y.0582 U.316 V-.0167 N0080 X-1.0977 Y.1163 U.3147 V-.0333 N0090 X-1.0901 Y.1741 U.3125 V-.0499 N0100 X-1.0794 Y.2313 U.3094 V-.0663 N0110 X-1.0657 Y.2879 U.3055 V-.0825 N0120 X-1.049 Y.3438 U.3007 V-.0986 N0130 X-1.0294 Y.3986 U.2951 V-.1143 N0140 X-1.0069 Y.4524 U.2887 V-.1297 N0150 X-.9817 Y.5049 U.2814 V-.1447 N0160 X-.9537 Y.5559 U.2734 V-.1594 N0170 X-.923 Y.6055 U.2646 V-.1736 N0180 X-.8898 Y.6533 U.2551 V-.1873 N0190 X-.8541 Y.6994 U.2449 V-.2005 N0200 X-.816 Y.7434 U.2339 V-.2131 N0210 X-.7756 Y.7854 U.2224 V-.2252 N0220 X-.7331 Y.8253 U.2102 V-.2366 N0230 X-.6886 Y.8628 U.1974 V-.2474 N0240 X-.6421 Y.8979 U.1841 V-.2574 N0250 X-.5938 Y.9305 U.1702 V-.2668 N0260 X-.5439 Y.9606 U.1559 V-.2754 N0270 X-.4931 Y.9876 U.1414 V-.2831 N0280 X-.4409 Y1.012 U.1264 V-.2901 N0290 X-.3876 Y1.0336 U.1111 V-.2963 N0300 X-.3332 Y1.0524 U.0955 V-.3017 N0310 X-.2779 Y1.0683 U.0797 V-.3063 N0320 X-.2218 Y1.0814 U.0636 V-.31 N0330 X-.1651 Y1.0915 U.0473 V-.3129 N0340 X-.108 Y1.0986 U.031 V-.315 N0350 X-.0506 Y1.1027 U.0145 V-.3161 N0360 X.0069 Y1.1039 U-.002 V-.3165 N0370 X.0645 Y1.102 U-.0185 V-.3159 N0380 X.1218 Y1.0971 U-.0349 V-.3145 N0390 X.1788 Y1.0893 U-.0513 V-.3123 N0400 X.2354 Y1.0785 U-.0675 V-.3092 N0410 X.2913 Y1.0648 U-.0835 V-.3053 N0420 X.3464 Y1.0481 U-.0993 V-.3005 N0430 X.4006 Y1.0286 U-.1148 V-.2949 N0440 X.4536 Y1.0064 U-.1301 V-.2885 N0450 X.5055 Y.9813 U-.1449 V-.2813 N0460 X.5559 Y.9537 U-.1594 V-.2734 N0470 X.6049 Y.9234 U-.1734 V-.2647 N0480 X.6522 Y.8906 U-.187 V-.2553 N0490 X.6977 Y.8554 U-.2 V-.2452 N0500 X.7414 Y.8179 U-.2126 V-.2345 N0510 X.783 Y.7781 U-.2245 V-.2231 N0520 X.8225 Y.7362 U-.2358 V-.2111 N0530 X.8598 Y.6924 U-.2465 V-.1985 N0540 X.8947 Y.6466 U-.2565 V-.1854 N0550 X.9272 Y.5991 U-.2658 V-.1718 N0560 X.9571 Y.5499 U-.2744 V-.1577 N0570 X.9845 Y.4993 U-.2823 V-.1431 N0580 X1.0092 Y.4473 U-.2893 V-.1282 N0590 X1.0311 Y.3941 U-.2956 V-.113 N0600 X1.0503 Y.3398 U-.3011 V-.0974 N0610 X1.0666 Y.2846 U-.3058 V-.0816 N0620 X1.0799 Y.2286 U-.3096 V-.0655 N0630 X1.0904 Y.172 U-.3126 V-.0493 N0640 X1.0979 Y.1149 U-.3148 V-.0329 N0650 X1.1024 Y.0575 U-.316 V-.0165 N0660 X1.1039 Y0.0 U-.3165 V0.0 N0670 X1.1024 Y-.0575 U-.316 V.0165 N0680 X1.0979 Y-.1149 U-.3148 V.0329 N0690 X1.0904 Y-.172 U-.3126 V.0493 N0700 X1.0799 Y-.2286 U-.3096 V.0655 N0710 X1.0666 Y-.2846 U-.3058 V.0816 N0720 X1.0503 Y-.3398 U-.3011 V.0974 N0730 X1.0311 Y-.3941 U-.2956 V.113 N0740 X1.0092 Y-.4473 U-.2893 V.1282 N0750 X.9845 Y-.4993 U-.2823 V.1431 N0760 X.9571 Y-.5499 U-.2744 V.1577 N0770 X.9272 Y-.5991 U-.2658 V.1718 N0780 X.8947 Y-.6466 U-.2565 V.1854 N0790 X.8598 Y-.6924 U-.2465 V.1985 N0800 X.8225 Y-.7362 U-.2358 V.2111 N0810 X.783 Y-.7781 U-.2245 V.2231 N0820 X.7414 Y-.8179 U-.2126 V.2345 N0830 X.6977 Y-.8554 U-.2 V.2452 N0840 X.6522 Y-.8906 U-.187 V.2553 N0850 X.6049 Y-.9234 U-.1734 V.2647 N0860 X.5559 Y-.9537 U-.1594 V.2734 N0870 X.5055 Y-.9813 U-.1449 V.2813 N0880 X.4536 Y-1.0064 U-.1301 V.2885 N0890 X.4006 Y-1.0286 U-.1148 V.2949 N0900 X.3464 Y-1.0481 U-.0993 V.3005 N0910 X.2913 Y-1.0648 U-.0835 V.3053 N0920 X.2354 Y-1.0785 U-.0675 V.3092 N0930 X.1788 Y-1.0893 U-.0513 V.3123 N0940 X.1218 Y-1.0971 U-.0349 V.3145 N0950 X.0645 Y-1.102 U-.0185 V.3159 N0960 X.0069 Y-1.1039 U-.002 V.3165 N0970 X-.0506 Y-1.1027 U.0145 V.3161 N0980 X-.108 Y-1.0986 U.031 V.315 N0990 X-.1651 Y-1.0915 U.0473 V.3129 N1000 X-.2218 Y-1.0814 U.0636 V.31 N1010 X-.2779 Y-1.0683 U.0797 V.3063 N1020 X-.3332 Y-1.0524 U.0955 V.3017 N1030 X-.3876 Y-1.0336 U.1111 V.2963 N1040 X-.4409 Y-1.012 U.1264 V.2901 N1050 X-.4931 Y-.9876 U.1414 V.2831 N1060 X-.5439 Y-.9606 U.1559 V.2754 N1070 X-.5938 Y-.9305 U.1702 V.2668 N1080 X-.6421 Y-.8979 U.1841 V.2574 N1090 X-.6886 Y-.8628 U.1974 V.2474 N1100 X-.7331 Y-.8253 U.2102 V.2366 N1110 X-.7756 Y-.7854 U.2224 V.2252 N1120 X-.816 Y-.7434 U.2339 V.2131 N1130 X-.8541 Y-.6994 U.2449 V.2005 N1140 X-.8898 Y-.6533 U.2551 V.1873 N1150 X-.923 Y-.6055 U.2646 V.1736 N1160 X-.9537 Y-.5559 U.2734 V.1594 N1170 X-.9817 Y-.5049 U.2814 V.1447 N1180 X-1.0069 Y-.4524 U.2887 V.1297 N1190 X-1.0294 Y-.3986 U.2951 V.1143 N1200 X-1.049 Y-.3438 U.3007 V.0986 N1210 X-1.0657 Y-.2879 U.3055 V.0825 N1220 X-1.0794 Y-.2313 U.3094 V.0663 N1230 X-1.0901 Y-.1741 U.3125 V.0499 N1240 X-1.0977 Y-.1163 U.3147 V.0333 N1250 X-1.1023 Y-.0582 U.316 V.0167 N1260 X-1.1039 Y0.0 U.3165 V0.0 N1270 X-1.1028 Y.0206 N1280 X-1.0996 Y.0409 N1290 X-1.0942 Y.0608 N1300 X-1.0869 Y.0801 N1310 X-1.0775 Y.0984 N1320 G00 X0.0 Y0.0 U0.0 N1330 M02 By the way 4 axis simultaneous motion like your cone part needs is always going to be linear (point to point.) Last edited by Mike Stevenson; 08-02-2008 at 01:54 AM. |
| Mike, Sorry if I fail to agree with you but any simultaneous motion should not be point to point. That is the whole purpose of simultaneous. I currently do five axis simultaneous and believe me if it was point to point, I would be extremely disappointed as this is not what I paid for. |
| Interesting Here is g-code I got , but had to change post's & some other setting's. Not real keen on NX5 Wire yet, but I will be ! ![]() N0010 () N0020 G00 G90 X-1.1039 Y0.0 G00 X-.7874 Y0.0 N0030 G42 G02 X-.5439 Y.9606 I-1.1039 J0.0 G02 X-.388 Y.6852 I-.7874 J0.0 N0040 G02 X1.1039 Y0.0 I-.5439 J.9606 G02 X.7874 Y0.0 I-.388 J.6852 N0050 G02 X-.5439 Y-.9606 I1.1039 J0.0 G02 X-.388 Y-.6852 I.7874 J0.0 N0060 G02 X-1.1039 Y0.0 I-.5439 J-.9606 G02 X-.7874 Y0.0 I-.388 J-.6852 N0070 G01 Y.0049 G01 X-.7878 Y.0036 N0080 G00 X0.0 Y0.0 G00 X0.0 Y0.0 N0090 M02 Harold C. |
| Yeah, you run that code H.C. |
| Don't plan on doing anything with it. If you remember what blmmdes posted, he was trying to get his code to post with arc's instead of linear movement so he could manually input it in wire. Just showing it can be done, didn't say it was correct. HAVE A NICE DAY. ![]() Harold C |
| Actually Ananth said, "For your info the motion format for our machine is X Y I J U V K L (XYIJ being programming plane co-ordinates and UVKL being auxillaryplane co-ordinates)" Where are your UVKL codes? Posting something and saying it can be done but its not correct is worthless. |
| Guys please... Hi guys, First of all thanks for your time spent on my problem. Mike, the output from NX6 is also in point to point format. i respect your preference of point to point output in 4axis simultanious moves but here the length of program is too long. Harold, Yes you got it right. thats the way i wanted. The first G02 in the block is programming plane co-ordinates and the next G02 in the same block is for auxillary plane co-ordinates. how did you achieved it? please explain. after postprocessing or before? i mean can you see coircular moves in the Listed *.cls file? Regards
#10
| Generate Arc's First I will say I think it is your post because I used the default 4th Axis post & got the same code Mike got. Having said that, go to your Operation Navigator, Right click on 4th axis & pick Edit\ Internal_Trim box -click Start/ End Events\ Machine Control box appears- check Start Events & open Edit \ User Defined Events box appears\ Highlight Set Modes- Click add\ Set Modes box appears\ under Arc Mode , change to circular & make any other changes that apply , & play. I hope this help's . Harold C |
#11
| Arc output Hello Harold, Please clarify...are you using the generic 4-axis post or its a customized one? Because i tried changing set mode>Circular but still my output is in linear moves. Are you trying to say that i have work on my post processor to achieve this? Thanks and Regards,
#12
| arc's This is the data path to post I used; c: program files=UGS=NX5.0=Mach=resource=Postprocessor=wedm_4axis_iso.pui . That is post I used to get code. Have a great day . Harold c |
| Programmed RS-232 output | ghyman | G-Code Programing | 13 | 07-11-2008 04:53 AM |
| 2 steppers on 1 output | rippe | Open Source CNC Machine Designs | 1 | 04-06-2008 12:47 PM |
| DRO with serial output? | DennisCNC | General Electronics Discussion | 1 | 12-16-2007 05:57 PM |
| Output arcs using R not I,J? | LongRat | SheetCam | 2 | 06-20-2007 01:35 PM |
| torodial output seems odd | trubleshtr | General Electronics Discussion | 3 | 04-21-2005 09:42 PM |
